Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 106
Thread: 996 Brembo brake project
  1. #51
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Quote Originally Posted by Remotion View Post
    Ok. Good to know. Did you need to change the U-shaped brakeline from end to other end because Porsche has calipers in front side of the wheel hub and bmw has rear wards from the hub?
    i would on the rears, thats how they are designed to work
  2. #52
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    Remotion, as fallguy suggested i also swapped the U-shaped lines from end to end before they were powder coated. I'm not sure if it makes any difference but it can't hurt.
  3. #53
    Nov 2005
    Finland
    Z3 Coupe individual
    Thank god they did not powder coat yet only media blasted. Going to the do that change.. and they will be btw in very similar color to yours. I went with RAL 5002 ultramarine blue and will put also white decals.
    This should be the right part of mine does break while trying to open them: http://teilecar.com/?2621,porsche-99...96100&sLang=en
    Thanks for all the answers.
    Z3 & E36 RamAir systems, send private message for more information.
  4. #54
    Nov 2008
    Kelowna
    Correct, left 99635296100 and right 99635296200
    Also put the seals back in the calipers before you have them powder coated, if you don't the powder will fill in the groove the seal fits in and they won't fit very well (don't worry they won't melt). You will need to plug the center of the seal where the piston would normally be so no powder gets in the bores.
    One last thing don't coat the mounts on the caliper (see photo).
  5. #55
    Nov 2005
    Finland
    Z3 Coupe individual
    Thank you very much. I think they will plug off all holes before powder.
    ps. do you really have V10 in the roadster? Any project topic about that or videos?
  6. #56
    Nov 2008
    Kelowna
    You're welcome.
    Yes there is a V10 in the roadster, it's not finished yet but it will be for next summer. I have started a build thread yet but I will. I have pretty much everything to finish it except for time...
  7. #57
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Z3 M Roadster View Post
    You're welcome.
    That's not fair--you have to at least start a thread.
  8. #58
    Newport News, VA.
    01 Z3 Coupe 3.0i, Z4 2.5
    Yaaasssss
  9. #59
    Nov 2008
    Kelowna
    I'll try to start one over the holidays.
  10. #60
    You're welcome.
    About time you shared it!
    Did you end up using the front subframe I sent?
    PRICE CUT on ALL FABRICS
  11. #61
    Nov 2008
    Kelowna
    LOL...
    Yes I did!
  12. #62
    LOL...
    Yes I did!
    Awesome. I put my signature on it since you told me what it was being used for... now I can say "my name is on that car"!
  13. #63
    Nov 2008
    Kelowna
    Did I mention that it was sand blasted and powered coated? signature is now gone
  14. #64
    I hid it on the inside as best I could and covered it in some clearcoat... I have faith some of it is still intact... maybe invisible but still there
  15. #65
    Nov 2008
    Kelowna
    Damn your sneaky!
  16. #66
    Nov 2005
    Finland
    Z3 Coupe individual
    My setup is ready for car. Thank you for initial responses that helped me on my way!
  17. #67
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Looking good. I should get my fronts installed haha
  18. #68
    Nov 2005
    Finland
    Z3 Coupe individual
    Fallguy, why they were out of the car? Have you felt that non-M brake master cylinder is a perfect fit for these brakes or would you change it?
  19. #69
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I just never installed the fronts yet, been swapping in a twin turbo LS.... just removed the ABS pump the other day for clearance.... will be relocating it.
    As for feel I didn’t notice much with just the rears. Was fighting some squeaks tho. Think I got it figured out. The pads I had were a little larger that the rotors. So I beveled the top and bottom slightly. They had a step in them from running over the edge of the rotor.
    Some day I will probaly make up some custom hats to use with a slightly larger bolt on rotor.
  20. #70
    Nov 2005
    Finland
    Z3 Coupe individual
    TT LS, so you are going "all in" with this mod. make a topic if you will.
  21. #71
    Apr 2002
    Florida
    Coupes...
    This is pretty cool. I have been sitting on this project for the better part of a decade. The crossover pipes are what I have been searching for.
    So thanks for sharing.
    White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
    I like Coupes.
  22. #72
    Nov 2005
    Finland
    Z3 Coupe individual
    We fabricated custom copper pipes, it was actually cheaper in factor of about 8x than the 100€ stealer pipes from brembo/porsche.
  23. #73
    Jul 2010
    Philadelphia, PA, USA
    2001 M Coupe, 2002 M3
    If you don't put the bleeders and crossover pipes in the correct orientation, you'll never be able to bleed the brakes. BTDT.
  24. #74
    Nov 2005
    Finland
    Z3 Coupe individual
    Quote Originally Posted by cleanerPA View Post
    Photos of the finished article are few posts above. Building and design phases are done.
  25. #75
    Jul 2010
    I wasn't quoting you, but anyway, my point was that correct orientation does matter. Leading or trailing edge, the bleeders should face up when mounted.
  1. E46 FS Porsche 996 Brembo brakes for e46. M/non M
    By BEAST 5 in forum Brake Kits, Rotors & Pads
    Last Post: 01-31-2013, 03:59 PM
  2. Replies: 1
    Last Post: 06-05-2003, 09:50 AM
  3. Regarding a Brembo brake upgrade
    By Vic328CSi in forum 1999 - 2006 (E46)
    Last Post: 05-28-2003, 11:17 PM
  4. 996 TT brakes fitment?
    By chazzy in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2003, 11:26 AM
  5. Brembo Brake kit GB!
    By Amir in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 09-18-2002, 01:43 AM
