Page 1 of 5 12345 LastLast
Results 1 to 25 of 106
Thread: 996 Brembo brake project
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    I've started installing the following:
    Front:
    Porsche 996 Brembo caliper, custom power coated and decaled
    Rally Road Bracket
    Rally Road stainless lines
    OEM Euro E46 CSL floating 345mm rotors
    Hawk HPS pads
    Rear:
    Rally Road Bracket
    OEM Euro E46 CSL floating 328mm rotors
    Hawk HPS pads(fronts for a NON S Boxster FYI)
    I've had very small pauses along the way. For example, the pads that came out of the Brembos, never seen anything like it before.
    They were described to me "dampeners". I am not sure if I need them. I will install the Hawks as is, If I need to I will scrape them free of the OEM pads and glue them onto the Hawks. So there may be a bit of trial and error there.
    I also found the stock rotor retention screw does not seat into the new rotors.
    I found ECS had the right ones and offered stainless ones for a dollar more so I have those on the way.
    While I have the car in this state I am addressing some little things.
    I had liquefied my wheel well splash shields when I drove with no bumper and thought zip tying them off the tires would work.
    I have had new ones sitting around for 4yrs so those are going in. I also bought all new under trays and ducts that attach to them as those were damaged. I've been an idiot and hit 130mph with none of that stuff there which I am sure created some lift.
    I have an identical setup for the brake on the rear which I will tackle next week after some travel.
    '98 RMS stage 2+++++(491whp/390tq VAC cams, CES Cutring-9:1, Built blower, Meth etc)
    '09 Saab 9-5 Combi 5mt 1 of 1(Built Motor, Brembos, LSD, the works!)
    '22 Cadillac CT4-V BlackWing 6mt
    '22 Cadillac CT4 2.0T Sport AWD (wife's)
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Wow, Impressive looking brakes.
    A couple of questions:
    - Do you have to change the master cylinder in order to keep the hydraulic design correct?
    - Are you keeping the original ABS unit?
    - Will the rear park/emergency brake still work with the E46 CSL rotors?
    - What sizes wheel are needed to clear the brakes?
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Quote Originally Posted by Muzz258 View Post
    Nope, no changes required
    Maintains ABS
    Parking brake still works
    I think 18's are required, though some of the aftermarket 17's are designed with big brakes in mind.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    What are the advantages of the 996 Brembos over the M Roadster Brembos?
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Apr 2014
    MD
    ‘97 M3/4/5 ‘99 M Coupe
    M roadsters came with brembos?
    For the rears.. are you using rear 996 calipers or the same front calipers for the rears?
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Quote Originally Posted by khammack View Post
    Umm, stock my car has steel single Piston calipers compared to these 4piston aluminum ones.
    Quote Originally Posted by MrDangles View Post
    996 rears.
    Denver, Colorado
    Quote Originally Posted by Jamesons Viggen View Post
    No, the question was why put on 996 Brembos when you could put on Brembos made for the M Roadster. Just wondering.
    https://www.tirerack.com/brakes/resu...2&autoModClar=
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Your link shows about $7k for front and rear. I had some hookups to get them so cheap, but I'm into it for under $2k.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I'm doing the same setup right now. But on a 3.0L. I got the calipers for 75$ each on car-part.com and got them powder coated red for 80$
    The whole setup is pretty good
    Lots of people say the stock ones are fine. From what I understand a multi piston will have a better feel than a single piston slider. Bigger rotors should also help. And they also look way better with the 18" wheels.
    Apr 2014
    MD
    996 rears.
    What are the rotor options for the rears? Do I have to run csl rotors?
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    I'm running 328mm csl rotors but there are cheaper options in the same size.
    Denver, Colorado
    That would be hard to pass up.
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Exactly. And at $1600-1800 I've done everything top shelf. I could have saved $300-400 by grabbing eBay or junkyard calipers. But for $800 a set, it was worth it to get the calipers coated and decaled to my specifications.
    Indianapolis
    F30 328d X-Drive
    That's really a great deal for what you are getting. I have plans to do this to my M as well. My main hold up is that I really love my roadstar wheels and would hate to part with them. I know someone on here made some 18" and 19" versions of them but I don't want to spend $4k on wheels!
    Looking forward to seeing your setup finished and on your car.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Quote Originally Posted by fallguy View Post
    The rear end of the 3.0 L is a lot smaller than the M, park brake shoes, rotor center housing etc. Are you using the same E46 CSL rotors and 996 calipers or something different to accommodate the smaller non-M rear end?
    Jul 2010
    Philadelphia, PA, USA
    2001 M Coupe, 2002 M3
    You definitely want to keep those funny looking cylinders on the back of the pads. Those are vibration dampeners and help keep the pads from making noise.
    Sent from my iPad using Tapatalk
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Quote Originally Posted by cleanerPA View Post
    I heard that's what they are called. But why aren't they on the new pads?
    Jul 2010
    For Porsche parts, they're usually sold separately and are attached to the caliper pistons, not the pads. I've seen similar things attached to pads on sliding caliper brakes, but not on a fixed caliper.
    I like this... May have to go down this path myself someday
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Thanks. Ordered an oem set. Why take a chance and skimp when a set of fronts were $50.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I got brackets for the rear from a guy on this forum. He is from Poland. His brackets use E36 M3 rear rotors, and they have a pressed in steel sleeve to make the ebrake smaller for the Z3
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Turns out the Hawks I had opened were for the rears.
    The fronts look quite different.
    My thinking is Hawk came up with their own dampener system hence the metal cylinders at the corner.
    I have a call out to Hawk. I do not know if they can or should be used in conjunction with the Porsche dampeners or in place of them.
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    So I spoke to Hawk. Just as I thought. The corners on the Hawk pads with the metal cylinders are their design for dampeners. They confirmed using my OEM new dampeners in conjunction with the pad is perfectly fine, its basically doubling up on anti noise measures.
    I now have all 4 corners bolted up. I just need to put on the lines(doh, needed to buy brake lines wrenches) and bleed the brakes.
    Only one thing is worrying me. On one of the rear Brembos, cylinder like fingers are forged into the caliper which allows the pads to seat onto them. They hover 5-8mm off the rotor. On this one though, on one side, its so close a pc of paper catches.
    Indianapolis, IN
    951, LTW M3, GTI
    Those cylinders on the edge of the pad can also be found on the factory OEM Pads....have a 997 OEM set with them in place.
    May 2013
    Manchester - UK
    1998 S50 ACS M COUPE
    I have the same set up on my M Coupe and it works well, a couple of things to note is the discs/rotors are handed and from the last picture they are fitted the wrong way round - part number ending 445 should be on the left side, also you can use part number 34111123072 as the disc retaing bolt for the front discs which is a smaller version of the one pictured.
  1. E46 FS Porsche 996 Brembo brakes for e46. M/non M
    By BEAST 5 in forum Brake Kits, Rotors & Pads
    Last Post: 01-31-2013, 03:59 PM
  2. Replies: 1
    Last Post: 06-05-2003, 09:50 AM
  3. Regarding a Brembo brake upgrade
    By Vic328CSi in forum 1999 - 2006 (E46)
    Last Post: 05-28-2003, 11:17 PM
  4. 996 TT brakes fitment?
    By chazzy in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2003, 11:26 AM
  5. Brembo Brake kit GB!
    By Amir in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 09-18-2002, 01:43 AM
