Results 1 to 15 of 15
Thread: Fuel gauge acting odd
    Nov 2015
    Pgh, Pennsylvania
    1990 735i 3.5/automatic
    I've never had a problem before and all of a sudden. I did leave my car get down between empty and a quarter of a tank. I went up to start it up and the gas gauge never moved at all.
    I shut the car off, and started it up again and it still stayed down on empty.
    I started it up at third time and then the gas gauge went up between empty and a quarter where it should be. It's done this two days in a row. Quite odd.
    I typically never let my gas get this low...but I haven't had the car out Much. Is the fuel too low and the tank even though it's sitting on the level, and it's just getting aggravated?
    after about the third start, the gas gauge works perfectly after that. Quite confused
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Nov 2015
    Pgh, Pennsylvania
    Thank you shogun, I guess that's my next project now. Some days I think this car makes me crazy.
    Richmond, Virginia
    '88 735i, '06 RSX
    I have this problem too but I'm too chicken to try and do this fix. Solution? Keep gas tank above half full haha
    Nov 2015
    Pgh, Pennsylvania
    Quote Originally Posted by youngbimmer View Post
    Im a little nervous myself. I just went up the garage, my garage is level obviously. It read between Empty and a 1/4 tank.
    Drove to the gas station and on the level it read a 1/4 of a tank after I drove the car. Ugh.
    I put it up to 3/4's of a tank. It seems fine.
    But I'll check it when it sits overnight. That seems to be when it does it unless it's my imagination.
    when you keep yours above half full does it NOT do it then?
    The reason I asked this, mine has never done this before, and I don't ever let mine go below a 1/4 of a tank. This is the first time I let mine go that low.
    Richmond, Virginia
    '88 735i, '06 RSX
    Quote Originally Posted by TonyPa View Post
    Mine starts misbehaving at the last 1/4 tank, so I just keep it above that. I was hoping the solvents like B12 chemtool, techron, etc would make a difference, but they did not. Has to be manually removed and cleaned with electronic contact cleaner eventually.
    Nov 2015
    Pgh, Pennsylvania
    I tried the same chemicals you did. I've never taken mine down below a quarter of a tank so I don't know if mine will behave the same. I usually get right below a half a tank and fill it back up. I just took mine off the 3/4 of a tank so I'm gonna check it tomorrow. And see what happens when I hit the key. Eventually I'm going to have to pull that out though and clean it. Which I dread doing
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    You know, both you guys are being forced to do the right thing here. It's a great idea to never let your gas tank go below 1/4 of a tank ever. You'll suck up a lot less crap into your fuel filter and eventually to the rail and injectors. So if having a sending unit not working right and it makes you put gas in when you're between 1/4 and 1/2 a tank because you're not sure where you are.....that might be a good thing. Fill Her Up.
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    Nov 2015
    Pgh, Pennsylvania
    Quote Originally Posted by CroughtonE32 View Post
    Oh absolutely I agree 100%. I Dont let my cars get down there a near a quarter of a tank. This is the first time I've ever really done that with this car. I just took to the store right now and it was fine went right up to 3/4 of a tank. I don't like sucking up dirt from the bottom of the tank I remember my dad preaching about that when I was younger.
    also some of the electronic fuel pumps, on the gasoline to keep them cool or so I was told on some cars.
    Like submerged and it
    Jul 2015
    Montreal, QC, Canada
    09/87 E32 750iL
    It's not too difficult to get the fuel sender out, I managed to do this too. With help from the forums, of course. Here are some pictures:
    http://bmwe32.masscom.net/sean750/fu...t/Fuelpump.htm
    http://bmwe32.masscom.net/johan/fuel...el_sender.html
    I really liked the idea of tying up the hoses so they don't get lost between the trunk floor and the tank. I also labeled the hoses so I knew which goes where. When you take the whole assembly out, the fuel hoses inside the tank have a tendency to get stuck at the edge of the tank, you really have to grab the whole thing, pull and turn at the same time. You don't see any rags in these pictures, but unless your tank is dry, you'll need them because fuel will be spilled.
    In my case the center rod of the fuel sender was rusted. The rust was in the middle and that explained why my gauge preferred showing half full or half empty. I tried to clean that, but it didn't help, I ended up buying a new sender.
    When I had this issue, I also had problems with my odometer. That was fun: road trips and neither a reliable fuel gauge nor a reliable odometer.
    Brantford ON Canada
    735iL - 1989
    There is a second opinion about fuel - the Reserve Light.
    Looking at page 6200-06 & 07 of the ETM, there is a separate switch on the B6 Fuel Tank Sensor that closes when fuel is low.
    So if the fuel gauge drops to 0, you are good to go until the Reserve Light comes on, and then you need to think about finding a gas station fairly soon
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    The pumps have a filter, then there is the inline fuel filter. And if there is crap in your fuel, you better shop at a different fuel station! The amount of fuel in the tank is irrelevant, being low on fuel will not cause more stuff to be sucked up by the pumps.
    ______________________________
    1992 750iL
    Jan 2005
    Japan
    Quote Originally Posted by unity View Post
    Yep, the fuel pump suction points are at the bottom inside the tank, all floating dirt, rust etc is basically heavier than the fuel and will go down by gravity, same with water/moisture = always at tank bottom.
    Plus there is one filter in each fuel injector = pre-fuel pump filter+ inline fuel- filter(s) between tank and engine bay + fuel injector filters
    Fuel Injector components:
    1. Top O-ring (Fuel Rail Side)
    2. Fuel Injector Filter basket
    3. Electrical Connection
    4. Solenoid (Electromagnetic coil)
    5. Pintle Valve return Spring
    6. Pintle Valve
    7. Engine Side O-ring
    8. Pintle Cap
    9. Pintle Seat or Fuel
    Jan 2005
    Japan
    Where is TonyPa? Last time seen on the forum May last year.
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    Not sure, hope he is ok. Wonder if he ever got his issue fixed. He usually writes back.
    His issues could have been either the gauge or sender, a cluster test should rule out the faulty gauge correct?
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
  1. Fuel Gauge acting up
    By SniperC4007 in forum 1988 - 1996 (E34)
    Last Post: 12-25-2012, 02:37 PM
  2. fuel gauge acting funky
    By curttaylor in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-21-2010, 11:40 PM
  3. Fuel Gauge acted weird this morning...any idea why??
    By jbro1988 in forum 1996 - 2003 (E39)
    Last Post: 11-30-2009, 12:46 PM
  4. I Hate Potholes (fuel gauge acting up now)
    By British in forum 1983 - 1991 (E30)
    Last Post: 03-15-2009, 05:15 PM
  5. Does your fuel gauge act up too?
    By E36Eric in forum 1991 - 1999 (E36)
    Last Post: 07-31-2002, 10:20 PM
