Hey guys!
I have worked all of our Canadian winter on preparing an e46 M3 for track duty. Roll cage, KW Clubsport, better braking, 2950 lb car.
Unfortunately I got a bit carried away with the wiring removal and have by mistake removed the wires at the yaw sensor under the driver's seat.
Mine is a 2002 with the 3 wire sensor. Later versions have 4 wires.
So here is what I need: What are the color of those 3 wires, which sensor prong is connected to which wire, and where do they end up, such as behind the fuse box. I still have the cut ends behind the fuse box and could re-wire everything.
I have pictures of the sensor if it helps. The Systron Donner yaw sensor part number is 3452-6 754 289
If you need any advice in how I built my car fire away!
My email is bmw635dude@hotmail.com
Thanks!
They all run to the DSC module which is in the compartment with the DME.. I dont know pin numbers off hand.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
This is for DSC MK20:
DSC MK60:
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
