RM European Auto Parts
Results 1 to 3 of 3
Thread: M50 chain replacement, oil pan.
    Aug 2014
    Norway
    1992 BMW 525iX
    Hi. Do I need to remove the oil pan to remove the drive chain?
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by DanielOrdal View Post
    Did you get an answer on this?
    88M3 AW 43k miles Project FS
    Aug 2014
    Norway
    1992 BMW 525iX
    The M50 has 3 chains, one from the exhaust cam to the intake/vanos, one from the crank and up to the exhaust cam, and one that goes down into the sump. One only need to remove the oil pan if the last chain is to be changed. If the main chain that goes from the crank is to be changed, one must take off the lower front chain cover, which is fastened to the engine block with a lot of bolts, and 4 bolts that goes through the oil pan. Also one must remove the water pump, all belts, trigger wheel, main pulley and a huge 22mm bolt that goes through the crank. I found out this when doing this job myself. There is a guide on the internet that says its mandatory to remove the tensioner for the airconditioner, but that is not necessary.
  1. replace oil pan gasket
    By eg8693 in forum 1996 - 2003 (E39)
    Last Post: 01-29-2007, 01:20 PM
  2. DIY for replacing oil pan gasket or power steering hoses?
    By mbanks21 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-08-2007, 10:55 PM
  3. Replacing oil pan gasket help
    By Z300991 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-02-2007, 11:32 PM
  4. Replacing oil pan gasket
    By bichmgnt in forum 1983 - 1991 (E30)
    Last Post: 05-05-2005, 09:31 AM
  5. Replacing oil pan gasket
    By drew900 in forum 1988 - 1996 (E34)
    Last Post: 08-20-2004, 12:19 AM
