Results 1 to 25 of 44
Thread: DIY - Degreeing Camshafts for Turbo M/S5x Engines
    Vancouver, B.C., Canada
    '97 M3
    It doesn't take much research to discover that the NA cam timing settings may not be the best for a turbo set up. Overlap is not a good thing if your engine has higher exhaust manifold back pressure. I had measured mine to be a 2:1 ratio to boost. When you read "overlap is great on a turbo engine" people are usually talking about a monster size turbo where the exhaust manifold back pressure is never as high as the boost pressure. That is not your average boosted BMW engine that we see on this forum (Yes, there are some exceptions). By trying different cam timing settings I found that as I reduced overlap the spool and transient response improved (based on datalogs). Then vacuum increased from about 15"Hg up to 18-19"Hg and the engine felt more crisp.
    To degree your cams you will need:
    • Magnetic base 1.000" dial indicator
    • Moroso 11" degree wheel (or any brand that tickles your fancy)
    • Stainless steel or steel wire to make a pointer out of
    • Small piece of plate steel to make a flat mounting surface for the magnetic base to stick to
    You will have to modify the degree wheel in some way to fasten it to the crank pulley. I took a piece of tubing and made an attach point to the degree wheel. This was version 1.0 for me. It made it more difficult to turn the crankshaft without access to the crank bolt.
    Another BF.com member had an easier, less eliquant method of attachment but actually much more user friendly than mine.
    Degree wheel mounted to the AC crank pulley and indicator wire bolted to the timing cover crank position sensor attach bolt location.
    Another angle of the degree wheel and pointer installed.
    Twisted SS wire bolted to crank position sensor attach bolt hole on front cover.
    Steel plate, cut to fit, placed over the spark plug holes and bolted down using valve cover studs. Drill hole in plate over spark plug holes so that air can move in and out of the cylinders as the crank shaft is rotated.
    Remove the screw in tip from the 1.000” dial indicator and replace with a 2” long piece of welding rod or equivalent. If you put a slight ‘S’ in the end of the rod it will engage the threads in the dial indicator and it will stay in place.
    Magnetic base 1.000” dial indicator sitting on steel plate bolted to cylinder head.
    This is how you would check piston to valve clearance during assembly of the engine. Replace the valve springs with weak hardware store springs, install the head on the assembled bottom end using a used head gasket of known thickness and tighten it down. Rotate the crank starting at 30° BTDC and stop at 5° increments through to 30° ATDC. At each position depress the valve until it contacts the top of the piston. Take a measurement with the dial indicator measuring the distance from valve seat to piston contact. Record all measurements.
    Once you have the degree wheel and pointer attached, rotate the crank shaft in the forward direction and stop at TDC for #1 cylinder. Never rotate the crank shaft backwards or it will screw the measurements. You can find TDC by using the timing pin, using a dial indicator on the top of the piston or some have used the timing marks on the front cover but I found that mine were off slightly. With the dial indicator installed on the steel plate you will need to position the dial indicator so that the end of the pin (welding rod) is between the cam bearing and the cam lobe and the end of the pin is contacting the lifter perpendicular to the face of the lifter. This is important for obtaining accurate readings. Intake and exhaust valves will be closed at this point. Zero the dial indicator by rotating the bezel (needle pointing to zero). Rotate the crank shaft until the dial indicator reads 0.050” and stop. The indicator is super sensitive so this may take a bit of practice. Don’t turn the crank backwards! Once at 0.050” write down the crankshaft degrees indicated at the pointer. ie. IVO 5° ATDC (intake valve open 0.050” at 5 degrees after top dead center). You can continue to rotate the crank until the needle on the dial indicator stops spinning in that direction. This will indicate peak lift of the camshaft ie. 0.453” or 11.5 mm. You can also record the degrees at which the center of the peak lift occurred. These are nice to know if you have bought some companies “Secret Sauce” camshafts and the company was too lame or scared to give you the actual specs. So, continue turning the crankshaft until you arrive back at 0.050” valve lift (0.050” before valve closes) and record this number ie. IVC 45° ABDC. Now do the same for the exhaust valve and record EVO, EVC and max lift.
    Now you have a bunch of data. You can compare the data that you have to the data that I measured and figure out what direction you need to rotate your cams to get the same cam timing. I’d recommend sitting down and doing some reading on why it would make a difference and what you are trying to accomplish with the set up you have. Take your numbers and enter them into the calculators at this site…… http://www.wallaceracing.com/Calculators.htm
    Now you have more data to play with, here is my data (Use the 0.050" 'R' numbers. The 'A' numbers are with the Vanos actuated)…..
    These recommendations that I have posted where with a GTX3582R open T4 .82 on an S52. If you have an M50 with a GT42R on it these may not be the ideal settings for you. YMMV.
    Timing the Schricks using the blocks gave me a LSA of about 113.8° whereas I have set mine to 119.7°. This does a few things. It reduces overlap which reduces the exhaust contaminating the intake charge and reduces combustion chamber temps. The other thing it does is opens the exhaust valve a bit sooner reducing pumping losses, helps spool the turbo as we will have slightly higher pressure passing through it. Closing the intake valve a bit later allows for us to get more intake charge into the cylinder even though the piston is on its way back up the cylinder on compression because of boost.
    Now, to actually adjust the cams you need access to the bolts at the exhaust cam sprocket. Loosen the bolts, adjust cams and I strongly recommend you measure the cam timing a couple of times to be sure that you got them both right. When you loosen the bolts for the exhaust cam sprocket either cam can shift slightly do to the valve springs acting against the cams. Check your Vanos travel after adjusting the cam timing as well.
    Happy Degreeing!
    Mar 2003
    Hell Hole, NC
    325i
    Thank you for taking the time to do a write up and sharing your knowledge.
    Mar 2012
    Renton, Wa
    98 m3
    High-five.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Aug 2011
    philadelphia PA
    1993 325is
    Fantastic!
    Thank you for sharing
    Phoenix, AZ
    1999 328i -2000 323i
    Nice post! Now don't you wish you had dual vanos?
    Vancouver, BC Ca
    1993 325is
    The ATI damper has some nice degree marks all around the outside that simplifies this process significantly. And speaking of dual Vanos, anyone think it'd be a good idea for a normally aspirated autocross car to boost the bottom end/mid-range torque? Motor is pretty "built" otherwise.
    Jun 2012
    South fla
    97 332i, 90 535i
    Great info here! Now if I could find a set of shricks for a great price I'd be in business!
    Sent from my SM-N920P using Tapatalk
    '97 M3
    I'll keep editing the original post as I remember stuff. I was insanely tired when I write the DIY.
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    I highly recommend checking the the cam measurements several times, my exhaust cam was off after doing the intake cam, big difference.
    I got smoother idle, better spool, higher vacuum and the fact that I can brag to people I didn't use the blocks to set my cams
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Matutino View Post
    But I get 19-20in vac by using the blocks. Also, can u put up a log of your spool now ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    May 2003
    Irvine
    Will do.
    Toronto, Canada
    E36 Turbo
    Awesome thread... You make Canada proud!
    Jun 2012
    South fla
    97 332i, 90 535i
    I as gonna say the same, i get 19 in hg now using the blocks and idle is smooth as can be! But I know there's room for improvement still. Good info here none the less!
    '97 M3
    The common causes for low vacuum are elevation (1"Hg per 1000 ft) intake manifold leaks, bigger piston ring end gap, idle speed, cam timing or advanced ignition timing. We could easily have any of those set up differently than your car or any one of those variables maybe masking one of the other variables. This is why I would not use engine vacuum to surmise if you have appropriate cam timing for a turbo'd engine and without actually measuring what your cams are set at we can only assume (attention Milky) that you have a lower LSA (lobe separation angle) set up for NA engines.
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Here me am.
    This post is GOD DAMN delight to our communinty.
    My Schrick sticks will be snug (one day)
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Awesome thread!
    If you have large enough mag bases you could probably put it on the Steed Turbo manifold and reach over. That way you wouldn't have to make a steel plate.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Well done on both logic and execution.
    Jan 2006
    Chicago, IL
    2003 330i ZHP
    Am I the only one that can't see the pictures? I'm logged in and unblocked content.
    '97 M3
    Quote Originally Posted by boostd4 View Post
    Are you on a phone or a compy?
    '97 M3
    Quote Originally Posted by 3literheater View Post
    Awesome thread! If you have large enough mag bases you could probably put it on the Steed Turbo manifold and reach over. That way you wouldn't have to make a steel plate.
    I have a PDF stencil of the steel plate that I can email to you to make it easier if you'd like.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by chikinhed View Post
    Pictures work for me on a galaxy phone and on my PC.
    Excellent write up!
    Oct 2005
    Northern California
    I appreciate that, but I am not at the motor build point yet.
    Also with my job I have mag bases that reach from 4" to 36" haha so I wouldn't need the stencil.
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    Awesome thread Chickenhead ?great write up
    Jun 2012
    South fla
    97 332i, 90 535i
    Ill have to keep this info handy for when I dial in the cams I don't have yet! Lol
    Feb 2010
    Texas
    01 530i
    Great thread, great knowledge, awesome!
  1. Camshafts for 1995 M3 S50 engine
    By egor328i in forum BMW Parts Wanted
    Last Post: 04-21-2013, 09:57 PM
  2. 296 degree camshafts for Turbo M3
    By mertdastan in forum Forced Induction
    Last Post: 03-13-2010, 06:08 PM
  3. Engine Internal Strength for Turbos
    By RRdawho? in forum Forced Induction
    Last Post: 08-27-2004, 05:29 PM
  4. how to build reliable e46 330 engine for turbo?
    By chase_rolls in forum Forced Induction
    Last Post: 11-11-2003, 03:13 AM
  5. Need Info for e36 316i '92 Engine (Turbo Project)
    By diegom6 in forum Forced Induction
    Last Post: 11-04-2003, 04:36 PM
