E36 Boostlogic Turbo Manifold + Rallyroad Engine Mount
One of the best bottom mount manifolds you can get.
Zero boost creep.
T4 flange
44mm wastegate flange
It has had a few cracks that were repaired. Three turbo mounting holes have studs welded in. The fourth is drilled out because I found it easier to tighten that side with a nut and bolt. I would suggest on getting? the engine side decked one more time to insure a good seal.
Also included is a rally road engine mount and turbo drain reservoir to use with a scavenger pump.
List Date: 5/10/2017
For more info, click here to view the original listing: E36 Boostlogic Turbo Manifold + Rallyroad Engine Mount
This item is no longer available.
Price drop to $500. willing to sell the motor mount separately.
Pm'd
― George Orwell
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Gg///M3. I've responded to your pm twice
Bump
Hate this new forum layout, can't even figure out how to send you a PM! My question is, does this manifold require use of a scavenger pump?
Any of this still available?
