Results 1 to 25 of 54
Thread: Swapping in M73 instead of M70
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    OK, so have to edit this Post a bit, I realize that there is an old wokke thread detailing the swap but it stretches to a novel that you need 3 hours to read! Wanted to compile in one place the number of changes needed for the swap.
    Will be doing this swap on a 91 850 with a bad M70 motor and retaining 4HP24 transmission.
    Without going into complexities of making a hybrid, the added cost of schrick cams, swapping heads and such I am rather interested in a simple swap.
    Wanted to verify If I am on the right track.
    Have a healthy pre 2000 M73 ready to go. Items that need to be swapped over from an M70 onto M73 (please add if I miss something).
    So far:
    1) Intake manifolds with DK motors and fuel rails.
    2) Valve covers.
    3) Rear coolant pipe connector(the one with 3 temp sensors)
    4) Use water pump from M73.
    5) Lower front timing cover (for crank case sensor brackets), grind the lower rear timing cover to fit the alternator arm.
    6) Harmonic Balancer.
    7) Use exhaust manifolds from M73 with modified down pipes to fir the stock M70 exhaust flanges.
    8) Use power steering pump along with tensioners and belts from M70.
    9) Use oil pan, pump with chain and oil sump from M70.
    10) Use shortened N73 crank bolt because the M73 crankshaft is shorter than M70.
    Missing anything else?
    Eprom wise, with slightly larger displacement possibly use 5.0 Alpina software, maybe CSI software? Or just a tuned set of chips like Dinan or Turner? Or even keeping OEM chips and going with 3.5 BAR regulators to give them a bit more fuel at WOT.
    Reasonable to expect at least 330HP at the crank?
    Thanks!
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    100 views and no one has any input? I sometimes feel the forum is starting to get away from technical threads...which is too bad.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    WOKKE did an excellent, in depth write-up of this procedure on this forum. It has all the answers you need.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Not interested in Wokke made hybrid using M70 heads. I am talking about a direct swap including m73 heads.
    Never-mind, did some more searching and found wokkes thread of doing exactly what I am trying to do, his hybrid thread is separate.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    or... you could just throw a Dinan TT motor into it...
    hehe
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by cartoonz View Post
    hehe
    Well
    If you sell it to me and not ask for 1 MILLION DOLLAS
    Sep 2008
    Santa Barbara
    ...with my little finger to my teeth, right?
    The OC, CA
    95 840Ci
    After all that, what the overall difference between what your doing and the hybrid? Just the heads?
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    If M70 heads are used schirck cams need to be purchased and installed and custom chip for more power.
    Sounds like M73 heads and engine can produce 360 HP which is more than enough for my purpose.
    Dec 2007
    Atlanta, GA
    M-Z3,535i, 320,Vette
    Quote Originally Posted by dragon850 View Post
    So far:
    2) Valve covers.
    Thanks!
    I can't think of anything off the top of my head- it's been a while since I hobbled together mine. The Intakes IIRC are the same but for some reason have different numbers. I'd definetly look at the M73's injectors- the blue Lucas ones. They are problematic as the center of the three hole center piece falls out (top one)-and screws up the spray pattern. I'd replace with Bosch ones.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    So use M70 Bosch injectors vs m73 Lucas? I was just thinking it would be nice to find a crashed Alpina B12 E38 750il with a 5.7l m73 and stuff that into an 850 with custom chip!!!
    Sent from my SM-G925T using Tapatalk
    Oct 2008
    Good old G. :D
    more and more Cars..
    Not interested in Wokke made hybrid using M70 heads....
    ...just because he knows that M73 heads are a step backwards...
    to register your 8 @ www.8coupe.com!
    Best regards from good old Germany Harry!
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by 8Harry8 View Post
    Wokke is running m73 engine with m73 heads in his own car. Just makes that m73/m70 hybrid for clients...
    Oct 2008
    Good old G. :D
    Whats wrong about it? He has learned over the years!
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Not saying anything is wrong, just stating a fact. I don't know, I have seen some high milage m73 that are running great, at least the banjo bolts don't back out on their own...
    Don't think roller rockers are a step backwards.
    Sep 2008
    Santa Barbara
    What weight of milk is being run instead of oil in that engine, 2%, half and half, or heavy cream?
    Me thinks that motor has some bigger issues....
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    My thoughts as well.
    1993 850Ci.....18 years & 165,000 miles and counting!
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    I wish I would. The car is still on the hoist since I have no time to finish it. I don't think the M73 heads are worse than the M70 heads. But I also don't think they are any better and that's why I prefer to use M70 heads because the entire down pipe issue is solved that way.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Considering the costs of replacing the engine with a M73 + new cams + labour + what ever, why not buy an N73 and having no problem with worn out cams and also getting 400+ hp!
    Nov 2013
    Whitney, TX
    97 850CI
    Here is a N73 for 13k. It also has a BMW 760 attached to it.
    https://www.carstory.com/detail/2006...HN03596DD98273
    Or here is a long block.
    http://www.ebay.com/itm/03-04-05-06-...hY8AlK&vxp=mtr
    Desecrator of all things Sacred
    The OC, CA
    95 840Ci
    From what I understand the N73 will not fit under the hood, unless you do a Chevelle SS style scoop or something drastic like that. Nice try though, that would be awesome! I wonder what it would really take to get and n73 in there? While Wokke's hybrid is appealing, I like the simplicity of what Dragon is proposing. The only thing I was going to mention was the fuel pressure regulators, but it looks like you've covered that.
    Sep 2008
    Santa Barbara
    the N74 is the only one worth putting a dry sump on and stuffing it in there... and not have to mod the hood either.
    Too bad Dinan burned through all the remaining S70 blocks from BMW... that was the perfect upgrade
    Quote Originally Posted by peake View Post
    and how do you want to control the engine? There is more than just mechanical issues like fitting the engine under the hood.
    M70B54 or M70B54S is more or less plug&play which is a huge advantage.
    Sep 2017
    Norway, Oslo
    E60 525D, F10 525D, E31
    Folowing. Could you post the progress with pictures? I to have a 850 with bad head gaskets and want to swap it to m73.
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Quote Originally Posted by wokke View Post
    So Wolf... Just reading this post and it has me a little worried. Are you saying that you would recommend the M73 bottom end with M70 heads over the entire M73 swap??
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
  1. Put in diesel instead of gasoline by accident!!!!
    By C///M3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-09-2006, 09:09 AM
  2. why are style 68 wheels 245 in width instead of 255?
    By Ridgeway in forum 1999 - 2006 (E46)
    Last Post: 08-29-2005, 10:33 PM
  3. Negatives to staying in DEs instead of racing?
    By sfzBimmer2 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-05-2004, 08:06 PM
  4. Is it ok to drive in "4" instead of "D"?
    By DOO in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-03-2002, 12:45 PM
