Results 1 to 20 of 20
Thread: Puffing sound from engine
    Mar 2014
    Minneapolis
    2000 Z3 2.3 & 14 allroad
    When the car is idling, I can hear a "puffing" sound coming from under the hood. My thinking is that it is an exhaust gasket. I'm not getting any codes from it, just this noise. It sounds like a ticking or like air escaping. It changes with RPM. It's not loud enough to notice when driving, so seems like a minor leak. I thought about the air pump hoses, but I have replaced those, and I believe it is a constant pressure, so would sound more like air escaping a balloon than this does.
    Any other thoughts? Also, engine noise level seems normal... it's not louder than usual or anything. Runs great!
    St. Louis, MO
    1996 328i race car
    Quote Originally Posted by SounderMN View Post
    I think you have pretty much nailed it. To further diagnose, you can try slowly moving a tissue around the area to see where the blow is coming from. You will probably have to disable the fan for this to work.
    Sent from my Nexus 6 using Tapatalk
    Chris
    NASA GTS2
    Springfield, Ohio, USA
    1998 Z3 Roadster
    I would check the Secondary Air Pump Solenoid on the exhaust manifold. They fail pretty often and when they do, they allow hot exhaust gas to enter the Secondary Air Pump, destroying it.
    It could also be a CCV problem. There are various ways to check that if you do a search.
    It could also be the famous VANOS rattle, which is harmless. That sound would come from VANOS solenoid at the top front of the engine. There are some YouTube videos of the VANOS rattle that you can use for reference.
    Feb 2014
    O.C. Oregon
    E36-E367-E39-E53
    Your spark plugs are loose.
    ​~Mike
    Tim @ BMW of Dallas
    98 Z3 2.8
    Quote Originally Posted by HeliHover View Post
    Exactly what I was going to say. I've seen this several times.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Mar 2014
    Minneapolis
    Okay, guys. Loose plug? That cant be it, I'm thinking... the car would run badly. But, worth a look. Guess what... one of the plugs was loose. You guys saved me a ton of work that would have done nothing! Thanks! :-) I love this forum!
    Feb 2014
    O.C. Oregon
    E36-E367-E39-E53
    Always glad to help. I was once in your shoes too.
    Let me guess, you have Bosch plugs?
    ​~Mike
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Many years ago I stopped to help someone that had broken down in a Mini (the original ones). I was very surprised to open the bonnet and discover that one of the plugs had come completely out and was flapping around on the end of the HT lead!
    Mar 2014
    Minneapolis
    I don't know if they are Bosch. Is that common with Bosch plugs?
    Feb 2014
    O.C. Oregon
    E36-E367-E39-E53
    To my understanding, yes.
    ​~Mike
    Oct 2016
    West Central Indiana, USA
    2000 BMW Z3 2.3
    The same thing happened to me a few months after changing plugs with new Bosch ones. I use a torque wrench on everything so I was a bit shocked when it happened.
    If it puffs more than twice you need to kindly remind it that its time to pass it on.
    PRICE CUT on ALL FABRICS
    Mar 2014
    Minneapolis
    Quote Originally Posted by BimmerBreaker View Post
    No Bogarts allowed. :-)
    Kidding aside, I have never heard of plugs getting loose like this. At least it's an easy fix, and I was smart enough to ask people smarter than me. HeliHover and Tim identified it right away... it would have taken me forever to figure it out. It's just a very strange thing, and I will know what it is next time for sure!
    If it does happen again, I'll be changing out those plugs for something different.
    Make sure not to use anti-seize
    Oct 2016
    2000 BMW Z3 2.3
    This might have been my problem. The arguments for and against anti-seize are equally loud and prevalent on the interweb. Not being able to tell the good advice from the noise, I opted for a small amount in hopes it would prevent the plugs from getting fused to the head. I don't know how many miles later the plug loosened up, but it was probably about 3k given my normal driving amount.
    Nov 2018
    van nuys CA USA
    2003 PT Cruiser
    Spark plugs are fine
    Spark plugs are fine. A Youtube video shows a (clicking sound) when a plug is loose.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Quote Originally Posted by catsoooooooo View Post
    If you read the thread you'll see that the plugs were loose, but thanks for the input.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I might as well add to this, since it came back up. I was sure I needed a head gasket. it was "Puffing" as said here, no "clicking". Did all the checking, listening, reading, etc. Then someone suggested loose spark plugs. That was it, problem solved with ease. I had installed them, probably afraid to strip the threads, because I had done that on a motorcycle head once. So, not too tight, and not too loose.......
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    A friend with a 330i had the same issue FWIW. Loud clicking/puffing from cyl6. We feared the worst, but it turns out the spark plug was loose!
    SW Florida
    99-01 M Cpe & Rdts, X5M
    There's a tightening spec on the box and I recommend it be adhered to. If you DIY them, go back a week or so later and check them (yes, takes a few minutes, depending on model, but can avoid a problem...). If you paid to have them done, and are comfortable checking them a week/a month later, do so. Just do not over tighten them__use a quality torque wrench__and do them with the engine cold.
    Left uncorrected, like on an overnight drive from Virginia to Ohio, a loose spark plug CAN CAUSE DAMAGE. When #5 was blown completely out out of the threads, and left to continue arcing for hundreds of miles, the damage and resultant repair isn't slight.
    Had to pull the head on this 2.8 to effect a repair; top sealing surface for #5 plug required spot-facing to save the head, along with a thread repair insert.
    Surface was only cut deep enough to get smooth/flat seal, but that still allowed the plug to protrude too far into combustion chamber...
    ... requiring the use of >.070" worth of sparkplug indexing washers!
    So, CHECK those plugs!
  1. Whirring/tapping sound from engine last night
    By MoŽ in forum 1992 - 1999 M3 (E36)
    Last Post: 10-15-2003, 03:33 PM
  2. strange sound from engine bay, advice??
    By mrclam in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2002, 10:28 PM
  3. Static electricity sound from engine when revving
    By alan2990 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-14-2002, 03:33 PM
  4. Hissing sound from engine
    By Brett in forum 1992 - 1999 M3 (E36)
    Last Post: 04-12-2001, 05:04 PM
  5. wierd sound from engine after long drive
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 03-06-2001, 10:25 AM
