Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: My e30 M50b25tu OBDII turbo build
  1. #26
    Mar 2016
    Australia
    e30 318i, 135i
    The 6262 is pretty laggy to be honest. It's just a little too big for the b25 i think, at least in a open T3 manifold. I dont have full boost (20psi) until about 4k rpm.
    When i sized the turbo i actually had a b28 bottom end which i think would have helped with spool more. The b30 bottom end in my garage will be perfect with this turbo i think.
    The gauge in the vent is a defi HD clone from aliexpress. Has inputs for fuel pressure, oil pressure, oil temp, coolant temp, boost, AFR, manifold vacuum, EGT and a couple more i think. It's gimmicky though as it doesnt actually log anything that you can export, you can only "play back" the recordings on the screen so its useless for tuning.
  2. #27
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Quote Originally Posted by Maad325 View Post
    Sweet build! Very similar to what I'm going to be doing with my M52 swapped e30 although its a stock engine but will be running flex fuel and some other goodies. How is the response with the 6262 on the GoodnTight manifold? A 3582 is in my reach is why I ask, also what gauge setup is that in your vent? looks mad
    m52 e30 with a G&T manifold and 35r with m3 cams and an obd1 intake, 3" exhaust and good tuning should see 15 psi before 4k.
  3. #28
    Mar 2016
    Australia
    e30 318i, 135i
    Going back on another dyno this weekend now that the fueling and timing has been refined.
    Wont be the same dyno so results arent comparable.
  4. #29
    Aug 2011
    philadelphia PA
    1993 325is
    Update?
    Cool work on the boost control.
  5. #30
    Mar 2016
    Australia
    e30 318i, 135i
    This dyno reads higher than the mainline so don't really know how much/any improvement there was
  6. #31
    Mar 2016
    Australia
    e30 318i, 135i
    Finally tracked down an LSD. Have been running an open 3.15 since day one.
    Found a well priced 2.93 LSD on ebay which even with shipping to Australia, is significantly cheaper than sourcing locally.
    2.93 should be an excellent match for the gs6-37dz.
  7. #32
    Jan 2015
    Australia
    Unknown
    Nice build mate. Where in aus are you located?
    WTB:
    S50/S52 cams + trays
    Rallyroad 60mm gauge holder + 52mm gauge holder
  8. #33
    Mar 2016
    Australia
    e30 318i, 135i
    Its been a while, life and fatherhood has got in the way a bit but i'm getting closer to starting the 2nd stage of the build.
    I've been accumulating parts for about a year now and am now in the right position to start. I'll build this motor first, get it ready to swap the current b25 out and straight in with the new m50b32 dual vanos.
    So far i've got:
    M50 block
    JE 9:1 86.5mm pistons
    K1 135mm rods
    M54b30 crank
    M50NV Head - modified to fit dual vanos from M54b30
    E46 ZHP Cams
    M50 cam trays modded to fit ZHP Cams
    INA 35mm lightweight lifters
    EFR 9180 1.05a/r twin scroll
    87mm cutring head gasket
    ARP studs
    ACL bearings
    Aluminium Forward facing Intake Manifold
    N62 82mm Throttle body
    HPX-e MAF
    Otis will be building me a custom manifold to fit this into the e30 whilst retaining AC and navigating around the RHD steering linkage
    Engine will be run on an MS43 ecu. I'm still debating whether to run the e46 pedal. I have a servo from an z3 that enables me to use the stock e30 pedal but retain the DBW setup. I'll figure that out once i start pulling things apart.
    Aim is for 700-800hp which should certainly be achievable.
  9. #34
    Aug 2011
    philadelphia PA
    1993 325is
    Thats whats up. Too many people sleeping on the dual vanos and ms42/43 stuff.
  10. #35
    Mar 2016
    Australia
    e30 318i, 135i
    compression numbers from the old smokey engine... bye bye rings!
  1. My 1998 E36 M3 turbo build
    By dakare36m3 in forum Forced Induction
    Last Post: 11-01-2013, 04:47 AM
  2. E30 M3 S52 Turbo Build
    By KarlSpackler in forum Forced Induction
    Last Post: 02-01-2011, 02:49 AM
  3. My 95 M3 EURO Turbo build
    By GasFed m3 in forum Forced Induction
    Last Post: 07-11-2010, 11:04 AM
  4. My 535/M106 E34 Turbo build!
    By vision79 in forum Forced Induction
    Last Post: 12-31-2007, 06:37 AM
  5. my E30 vs 997 Turbo, but WHY??
    By M3isgod in forum 1983 - 1991 (E30)
    Last Post: 12-19-2007, 10:05 AM
