Hi guys I just move to San Jose and if anybody need help with diagnostic, reset airbag light, activate new function, programming new key to your EWS etc, add new module, coding, retrofit etc.
I can help with this.
I do all cars from late E36 to 2008 year (DCAN)
Programming new keys with EWS I, II and III
where are you located and how much for a key on a 01 e38? picking one up from a tow yard and it has no key
INSTAGRAM: @gv_sanjuan
Work hard.....
Play hard....
And laugh even harder......
PM sent
Why'd you move! I'm in Spokane and need a EWS alignment You think you could help me get my cable/INPA to work? It seems to be installed, but I get an error when doing anything other than reading codes.
apiresulttext error 19
ifh-0009 no response from controlunit
api job error no such result
I'm in Oakland and am trying to program an eBay key with the AK90. It seems to go fine when I program it - when I test the key it has the correct VIN. PA Soft shows a fault in the EWS that says the password is wrong for Key #4. I don't have any idea how to get the key to have the correct password. Is there a procedure or sequence to get the key synced with the EWS? I'm familiar with EWS>DME sync in INPA, but I think this is different
Here are the errors from PA Soft:
EWS Hex: 42 Dec: 066 Wrong changing code - key 4 EWS Hex: 41 Dec: 055 Wrong password - key 4
Thanks in advance
you still in san jose i need a sync e66
