I know it's been covered before, but I have a 95 e36 325i sedan, and recently came across a set of front Vader seats. I started the swap because I read that it was the same bolt pattern, which it is. The problem I ran into is the seat belt lower mounting points by the doors. The previous owner swapped the electric seats for manual ones and drilled a hole in the plastic and ran an unsecured bolt through the bracket, into the plastic. The square tab in the plastic trim was not used, like it was bolted on the outside without a nut on the inside. The question is, without a welder or waiting for adapter parts, what are your suggestions?
Pics would help.
Without pics it is hard to tell but I think I understand what you're describing. The bottom of the seat belt on coupes mount to the body of the car while sedans are mounted to the side of the seat. The plastic trim with the square etched in the plastic is where the bottom of the belt should be inserted. However, you don't have to but it'll look ugly and the plastic side piece of the seat will be lifted. I used a dremel to the square etched part on the plastic. A T30 torx bolt from your old seat should be reused to secure the seat belt to the vader seat.
Your situation should be similar to mine as I put manual vaders into a 98 M3 sedan.
Bringing this thread back to life.
I have a 98 m3 sedan with manual, heated seats that I want to swap a set of manual, heated Vaders that I picked up into it. I thought the seats bolt right in and no modifications were nessacary? But now It sounds like the bracket where the seat belt mounts to the seat on the sedan, (that's secured by a torx bolt) is different than where it will mount to the Vaders? What's the deal? Do I have to cut the plastic, etc? Any pictures would be awesome! Confused here. Thanks! Just picked this car up! Modding within the first week! Hehe
