Fairly new to this and I got a 2001 BMW 325i and I'm trying to build the engine up a bit. I'm thinking of starting with a intake, headers, cylinder heads. But I don't know how much my engine could handle, not trying to blow the motor. So should I get a new block as well or just swap motors?
Welcome to the forum!
Should have started with a 330i instead, as that is what is sound like you want to get out of the car, as it has about 40 more HP stock.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
You can buy a complete turbo kit for one but then it depends on wat route you want to go down because that aint going to be cheap there is a couple of video on you of people with turbos on 325
Sent from my SM-G920F using Tapatalk
Thats ment to say on you tube lol
I wanted a 330i but I got the 325i for a steal so I just went with it. I know the m54 is a small motor so I'm just wondering if I swapped headers manifold and Intake if the motor would blow. Should I swap blocks as well? Or just full on engine swap?
Welcome. You are apparently new to BMWs. One thing's for sure, it ain't like working on a Chevy. Dealing with the hard parts isn't so hard. The electronics, that's another story. Unless you have a place to work, the necessary tools and the know how to deal with the electronics, as said above, you'd be better off looking for a 330.
Besides, did you just get the car? Odds are that it needs something. Cooling system overhaul, suspension, etc. Have you run a scan on it to see what kind of shape it's in under the hood? In my experience, people usually let these cars go after the warranty period expires and their idea of a well cared for vehicle is fixing it when it breaks. With a BMW, preventive maintenance is the name of the game. If you like the car and want to keep it running, give the cooling system some attention. Unless it's been done in the last 50k miles or so, odds are that it needs a top to bottom refresh. Radiator, thermostat, hoses, expansion tank, water pump, pulleys, etc. If one of the parts that keeps the engine cool goes, the head is at risk.
If you are a mechanical wiz and really know turbo systems, you could piece one together; otherwise, figure about $5k. I wouldn't spend that kind of money on a car that I only got because it was cheap unless I was building it with a purpose in mind.
Cut to the chase, source an e46-m3 motor.
Well I got it non running for $1200. But all it needed was the cooling system and a new head. My family friend is a BMW expert and owns a shop so I got the parts for a discount. Only put $800 and now it's running and perfectly fine. Passed very test. You're right I'm totally new to BMWs. I do have some help, and some money too. I know the m54 is turbo friendly but I'm no mechanical wiz... not yet at least. I'm willin. To work and pay for it to become one through.
The best advice I can give you is just drive the car first before making big plans.
Then start laying out a plan for that car or perhaps another one later on down the road. Then start to collect the cost of each item and the possibility of you being able to install them.
In the Military, we call that the "End State" and that is where you want the car to be at and how long it will take for you to finish the car.
Darin
Current:
Past:
M-Flight Member
__________________________________________________
Cars
Now, why didn't I think of that? But yeah, you really need to learn BMWs. I've been doing shade tree/driveway work for years and with the BMWs, I feel like a noob a lot of the time.Cut to the chase, source an e46-m3 motor.
When I got my son his '01 325i, we looked into what we could do with the car. Since his only had just over 70k miles on it, we figured it still had a lot of life in it. What we found is that "go faster" parts are expensive and all give the usual "up to 10hp" spiel. I've been around long enough to know that what that translates into in the real world is little to nothing. You could spend a couple of thousand to drop a 1/10 on your 0-60 time.
Driving a BMW is an experience in itself, due to the handling and behavior of the car. Get it running right and enjoy it for what it is. Get to know the car and the brand, then start making plans for something bigger. An M3 swap sure sounds interesting and would certainly provide the power.
