so i decided to switch back to singles instead of the twin e34 projectors i had installed. being im going grp2 kit, the singles look better i think.
only problem is the 2 old lenses i have are different, and one is a lhd pattern, no good for australia.
i figured id have a look at some led headlights to modernise it a tad, but dont like the look of most leds, so went with a reflector lens. doesnt look out of place i think, will see what real world lighting is like oneday :p
now the only problem is the e21 7" arent the same as a standard 7" sealed beam type headlight.
i like a challenge, havent found anyone else that had done this, so jumped in anyway
so first things first, the lights. ebay specials, quality looks alright, nice solid alloy heatsinks, decent cable and h4 plug
20170504_162828 by troy, on Flickr
brackets i decided on some harley adapters
20170427_170902 by troy, on Flickr
only problem is theyre quite bulky and i guess the oem setup was designed the way it was due to clearance issues
20170427_171724 by troy, on Flickr
luckily the spacing to bring the headlight out to roughly the right depth was spot on with the base of the harley mount, so chopped the tabs off and flattened them out, ground some clearance notches in the original brackets(pics to come) for the adjuster nuts, and will weld them into place.
received_10155146914520505 by troy, on Flickr
the chrome ring mounts and adjuster screw mounts need to be trimmed to clear the grille, but so far so good!
20170504_174645 by troy, on Flickr
this next pic is just the light sitting unsecured. will post more as i work on these with more detailed pics on the bracket modifications
20170504_174252 by troy, on Flickr
now these lights dont have parklight/citylight/whatever you want to call it in them, so was thinking just throw them in the indicators like the us ones. can i use the us housings with euro lenses? or do i just drill a hole in my euro ones and add a universal t10 socket
I did this with some 7" VW smoked crosshairs for my group 2 e21. I chopped up the VW mounts and welded them to the e21 buckets with the help of another member who did the same. Yours look good too.
Looked into an all LED setup on the racecar just for simplicity and low power draw. Found Hella makes a housing a lot of E30 guys use, so trying a set. They are smaller 5.315" and fit an H4 bulb. Plenty of H4 led sets to choose from. There have been plenty of leaps in tech on these so have to search. There are plenty of vendors still selling old tech style bulbs that work fine, but the middle road versions have moved up a notch.
can google 002850001 hella and find plenty of other vendors; these fit H4 bulbs and popular with other 80's cars
88 M3
91 318is
91 318i
83 320is
08 X3 3.0si
spent the afternoon chopping and welding. brackets just need a lick of paint. not really much point touching the welds, will never see them. theyre not great(second bracket was a bit better, its been well over a year since welding anything) but amateur with a gasless mig doesnt help either :p
mainly just had to trim the outer ring mouting ears down as much as i could(forgot a pic)
20170510_161049 by troy, on Flickr
20170510_173304 by troy, on Flickr
20170510_161834 by troy, on Flickr
20170510_162446 by troy, on Flickr
That's nice! More Pics Please!
