Hey guys I've been out of the game for a bit, recently changed out my injectors (had 1000's) and am looking to upgrade my current pump setup. Currently running dual 255's (one shit out) and ID2000 injectors.
Looking for something to flow enough for 1000whp on E85. What is everyone running now a days?
///Andres
11 X5d sport - daily tow rig
09 335d - evolve tuned 327whp / 490wtq
97 M3 - NASA TTB
95 M3 Turbo - 3.0l s52, PTE74GTQ, AEM EMS & CDI, etc
I feel like ill be in the same boat soon.
Right now ive got 2 walboro 450's in there and on paper they should support 1000whp but im not too optimistic.
Ill know in the next week or 2 if im actually screwed.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Im setting up a hardwired magnafuel 750 on the car now for e85. -8an lines all the way.
I have something coming down the pipeline very soon... single pump in tank (can be expanded to double), low amps, low noise, low heat... all fuels compatible.
Single pump should be capable of 800+whp on E85, and closer to 1100whp on gasoline.
If i have issues, ill probably move to a fuel cell and big external pump, even though its "unsafe and will slosh"
By my math you would need right around 500 liters per hour of fuel flow. Twin AEM 380's with good wiring should get you there. Walbro 450's would also be about right but they are only good for 80 psi or so. Make sure you have good good good wiring to the pump with no resistance in it. Keep in mind that the pumps do not quite flow there advertised amount when actually installed in a car due to voltage drop and pushing through hose.
Personally I am sick and tired of external pumps so I am moving my twin AEM380s into the fuel cell. I'm tired of a cluttered up trunk.
Off topic but stay away from the 2000s for E85. If you were in Nevada and daily drove it, it'd be one thing but in the Northern climate, it's just too damn humid. The 2000s are the greatest injectors for their size but that's because they have an iron core, which makes them extremely susceptible to rust. I tried to make them work by making sure I ran the car every few weeks at least but one of them still started acting up. Get the 1700x
Subscribed. I'm running twin 450's in tank, but using stock fuel lines. Interested if someone starts selling bent SS hardlines in 1/2 inch
Sent from my SM-G935V using Tapatalk
Walbro standard 255 (non-e85) in tank feeding two Walbro 450's (E85 rated) in a radium surge tank and ID1700 injectors. On 83% Ethanol, base pressure 45psi, @ 26psi boost pressure, rising rate FORE regulator the duty cycle was around 80% at just over 1000rwhp (Dynojet SAE). All PTFE fuel lines. Only thing left to swap in is the old in-tank fuel pump which has lasted over 4 years...knock on wood.
I had ID2000's for 4 years in the same setup...worked great with over 40k miles. Ran pump...various contents of ethanol up to 98%. I wouldn't worry if you had a set of ID2000's already but if buying new go with the 1700's imo.
I'd try the new brushless fuel pump from radium if I had to start from scratch...run that in my surge tank. Lots of people are using the new brushless setups and Injector Dynamics has a full pump setup in R&D for the better part of a few years now...last I saw it was in the final stages after finding some hot spots on the circuit boards that needed a heat sink added. Paul Yaw doesn't fool around lol.
1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
People always chuckle when they see the booster in the back of my M3.
I'm running two walbro "485s" but with the higher pressure relief valve that opens up at 110-120psi on a RR hanger. -8 feed from the pump that goes through a older Ross racing Machine fuel rail then a -6 return back to the tank where its split to return to both sides of the tank.
Anyone running a jet pump on the return to draw fuel over from the other side of their tank. Radium now sells one that's aluminum, but it's not cheap. Aeromotive sells one with their eliminator setup and I conned them into selling me one at one time for like $15. I think the part was actually a stock corvette or mustang piece but I could never find one.
On the topic of brushless. I think there's a stock (possibly buggati) pump that the GTR crowd is using
Their jet pump looks good, hopefully it sucks. I think that would be a good idea for someone with a surge tank but when our cars are doing a hard pull (no surge tank) with less than half a tank the fuel goes to the back of the tanks exposing the pump pick up in the little factory sump. It's even worse if you are trying to go through a long RH sweeper.
I didn't want to fill up my trunk with fuel pumps and surge tanks etc so I put a Walbro 450 on each side with the drivers pump mounted to the bottom aft outside corner. I have had no loss of fuel pressure accelerating or in long RH sweepers since running it right down to the reserve light. Both pumps run in parallel through -6 (3/8") lines feed and return. I'm only at 660 whp though. I'll do -8 when it's needed.
On my last projec I utilized the stock jet pump on the drivers side as a "mount" to hold four of the following at the bottom of the fuel tank. They were spread out to the four corners of the drivers side fuel tank. Then i had a jet pump mounted on the passenger side, along with my fuel pumps, to draw fuel over to the passenger side. Never got to run the setup, but worked flawlessly in a fishtank partly filled with water and sloshing it around
http://www.autoperformanceengineerin...l/pickups.html
Many set-ups out there running over 1000 whp on E85 on twin wablro 485's. A lot of it depends on how much boost pressure your running and your base pressure along with fuel line sizing.
Attention TURBO LOVERS, Great book -----> How to turbocharge and Tune your Engine
Favorite Automotive Tuning Articles on the Internet: Engine Tuning Articles
My Car: Custom Build Lotus Super 7
Went with 1700's as it was better matched for my power goals. Base pressure was 45 on my 2000's and it idled down to 800rpm reliably on pump fuel. As for the 1700's I haven't ran pump fuel on them yet but I suspect I could run a slightly higher base with pump fuel but there's been no need to change it yet. Plenty of other things to play around with.
SO i had my car on the dyno not too long ago.
twin 485's, i assume the older ones with lower pressure releif valve. One pump in each side of the tank
-10 feed
stock jet pump thing still functional
-6 return split to both sides
2200cc bosch injectors
E90 fuel
on about 24 psi, it was dropping pressure. Power was low for the boost (780ish on a mustang, through an auto) but later found out i had thrust bearing issues and a slipping trans (almost back together)
The equalization from side to side sucks. Came up with an idea to add bulk heads and a cross over and later found out thats exactly what the porsche guys do too.
also, the fuel guage is crazy. Cant trust it. Hopefully, getting the sides equalized helps with that.
at full boost, it was about 78% DC with dropping fuel pressure, targeting 11.5 AFR on gas scale. This is a twin turbo LS engine and TH400.
The issues you are having with the saddle tank are the exact reason I put a fuel cell in my car.
