Results 1 to 25 of 50
Thread: ► APEX | FL-5 Lightweight Track Wheels
    California BAY AREA
    e30 M3, 335d
    Introducing the all-new APEX FL-5
    The FL-5 is the only APEX design that that takes advantage of Dual Flow Forming plus our newest "I" beam machining technique. Still a one-piece wheel, the Dual Flow Forming technology strengthens both inner and outer barrels while maximizing front lip depth for each unique width and offset. Overall strength has been increased over previous designs which ensure durability in both street and track environments. The advanced "I" beam spoke milling further reduces weight and adds a visual feature typically only found on the most expensive race wheels available on the market today.
    Visit our website to order
    The New Stuff
    1. "I-Beam" Spokes
    This is the most significant new feature we've added. Weight is reduced by CNC machining material out from the sides of each spoke. It's expensive and avoided by almost every manufacturer, but we've made it affordable through volume production.
    2. Factory Support
    Like all our APEX wheels, The FL-5 supports all OEM hardware like OEM Roundel center caps, wheel lugs, valve stems, and TPMS sensors. No centering rings are needed either.
    3. Beefier Lips
    By saving weight elsewhere, we've added extra material where it counts. We beefed up the barrel's inner lip to better handle the abuse from the street and track.
    4. Dual Flow-Formed
    The FL-5 is our only design with a front lip, and it's also our only wheel that features the use of rotary forging for both the front and rear barrels. We did this because we needed to produce the strongest front lip possible, and we can optimize the depth of the front lip for every unique width and offset when we use this more advanced production method.
    Designed for the Performance Enthusiast
    Light-weight
    Flow-forming allows for a significant reduction in rotational mass by reducing barrel weight. This manufacturing technique allows our wheels to be almost as light as a traditional forged wheel, but without the significant increase in price.
    Strength
    Track duty requires a wheel that can handle the punishment of high lateral G's, hitting berms, and every once in a while, a small off track excursion. Spoke and barrel design are a major factor in wheel strength. The flow-forming technique uses high pressure disks/rollers to roll the wheel's barrel into its final shape. This gives the barrel the same strength properties as a forged wheel, since monoblock wheels go through a similar step to form their barrels. We design our spoke dimensions to help evenly distribute loads from the barrel to the center of the wheel. The lack of a front lip, and spokes directly connecting to the edge of the wheel, also add increased strength to the outer lip of the wheel.
    Chassis-Specific Fitments
    Stretched rubber, narrow tires, and fender rubbing are not elements to look for in a competitive wheel/tire setup. All of our wheels were designed with offsets that allow for proper fitment of extreme summer, and r-compound tires without the need for spacers or fender rolling. This means keeping the tire under the fender, and away from suspension components. Track oriented wheel widths are also important as they provide proper sidewall support under hard cornering. Too much rubber for a wheel results in excessive sidewall deflection, which translates into sloppy and delayed turning response.
    Multiple Fitment Options
    Most BMWs come with a staggered setup from the factory. Some choose to keep their car this way, while others like to switch out for an easy-to-rotate, square/neutral setup. This is generally based on driver's preference and consideration of tire costs. Most BMW chassis benefit from being able to fit both square and staggered setups with relative ease. 9.5" or 10"-wide square setups are great for budget minded enthusiasts who want to extend their tires life by rotating between events, in addition to preferring the feel of a square setup. Square setups are popular on all models for track use due to the significant increase in front grip and turn-in response. Some owners comment that due to the extra power of their cars, a square setup will lean towards oversteer. For those who prefer more rubber in the rear, a staggered setup is the way to go. Wheels up to 11" wide are available for rear fitment. These can be combined with 9.5" or 10" fronts for a bolt-on spacer-free staggered setup.
    BBK Clearance
    Many owners install Big Brake kits on their cars. Having a smaller-diameter wheel that can clear large calipers is a must. Due to the low-offset nature of many BMWs, there are no clearance issues with the concave spokes. Barrel clearance was increased during the design phase to accommodate both StopTech and Brembo's 380mm kit.
    The APEX Standard
    1. FEA Optimization
    We took more time than ever before on this step, revising and iterating our design to reduce weight as much as possible. After countless iterations we removed material from the sides of the spokes in a way that allowed us to increase strength over our previous designs.
    2. Always Flow Formed
    All APEX wheels feature Flow-Formed construction that utilizes rotary forging to produce a strong and lightweight barrel. The FL-5 is no exception.
    3. True JWL & VIA Certification
    Strength needs to be certified. Our wheels were not simply FEA tested in a computer simulation, or in-house tested to an unregulated standard. We conduct real-world crush-testing and all of our wheels conform to Japan's JWL standard, as well as being 3rd-party tested by the VIA. All of our wheels carry a 690KG load rating.
    Available Finishes
    Sizes, Weights, and Pricing
    Questions about tires, fenders, brakes, spacers, or suspension clearances?
    Click here to get a personalized fitment recommendation from one of our experts.
    Lip Profiles
    On-Car Photos & Renders
    Check out our extensive collection of photos on our Flickr page. See more photos >>>
    Tire Mounting and Balancing Service
    Popular street and track tires are now available when you order APEX wheels. Add tires with your wheel order and get free tire mounting and balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. With our competitive tire pricing bundled with the savings of free mounting and balancing and convenience, it’s the ultimate wheel & tire package.
    *Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be cancelled and refunded.
    Available Tire Brands:
    Ordering and Contact Information
    • Hours: Monday - Friday, 9AM to 6PM PST
    • Shipping: All orders are shipped directly from us via UPS. Local pickup also available at our Livermore, CA Warehouse. (Map It)
    California BAY AREA
    e30 M3, 335d
    Our new FL-5 wheels are available for pre-order and we are offering enthusiasts Free Shipping on a set of wheels for the rest of May. Check them out on our website here!
    California BAY AREA
    e30 M3, 335d
    We love the design of our new FL-5 wheels! Pre-Order today and be one of the first to run these wheels on your car :party0030:
    California BAY AREA
    e30 M3, 335d
    What do you think about the new lip on our FL-5 wheels? We think they look great! :thumsup:
    California BAY AREA
    e30 M3, 335d
    The new FL-5 wheels are scheduled for a June 2017 delivery! Pre-order today and be first to get your hands on a set of our new wheels!
    California BAY AREA
    e30 M3, 335d
    Most of our FL-5 wheels will be in stock this week, with remaining fitments arriving next week! We can't wait to see these wheels on your car!
    California BAY AREA
    e30 M3, 335d
    A good portion of our new wheels have arrived today! Orders will begin shipping out this week, with the remaining wheels arriving next week :thumsup:
    California BAY AREA
    e30 M3, 335d
    Check out our FL-5 wheels in the Satin Black finish! We have many sizes in stock and ready to ship. Remaining sizes will be in stock next week :party0030:
    California BAY AREA
    e30 M3, 335d
    Check out this E46 M3 with the new APEX 189.5” ET22 FL-5 wheels in Race Silver. Wheels are in stock and ready to ship! Place your order today
    California BAY AREA
    e30 M3, 335d
    Which finish do you prefer? FL-5 wheels are in stock and ready to ship! Order your set today!
    Nov 2003
    MIAMI
    E92 JB M3
    what are the specs on this M3, size, offset and tire size?
    Quote Originally Posted by Eddy@ApexRaceParts View Post
    Nov 2003
    MIAMI
    E92 JB M3
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by blown330 View Post
    That photo is actually a render using 18x9 ET30 all around with the rear fenders rolled. The 18x8.5 ET35 will also work without requiring a fender roll. Not 100% sure on the tire size but it does look a bit stretched, possibly a 225/40 or 235/40.
    California BAY AREA
    e30 M3, 335d
    Hit the track with a new set of FL-5 wheels.
    This Z4M is running 18x9" ET30 and 18x10" ET25 with 245/35/18 and 275/35/18 tires.
    California BAY AREA
    e30 M3, 335d
    All sizes and colors in stock and ready to ship today.
    California BAY AREA
    e30 M3, 335d
    Here's an E92 with 18x10.5" ET22 FL-5 wheels with 275/35/18 tires all around, no spacers required.
    California BAY AREA
    e30 M3, 335d
    18s can fit perfectly on an E36. Here's some 18x9.5" ET35 with 255/35/18 tires.
    Nov 2003
    MIAMI
    E92 JB M3
    Have any more pics?
    California BAY AREA
    e30 M3, 335d
    Have any more pics?
    We sure do, you can view all of our FL-5 photos on our Flickr account by using this link.
    California BAY AREA
    e30 M3, 335d
    We just love detail shots of our new FL-5 wheels. Check out those I-Beam spokes.
    California BAY AREA
    e30 M3, 335d
    Take a look at this render of an M2 rocking our FL-5 Wheels!
    California BAY AREA
    e30 M3, 335d
    This FL-5 setup is 20 lbs lighter than the stock setup on this E39 M5.
    California BAY AREA
    e30 M3, 335d
    TIRES NOW AVAILABLE
    • Michelin Pilot Super Sport
    • Michelin Pilot Sport 4S
    • BF Goodrich g-Force Rival S
    • BF Goodrich g-Force Rival S 1.5
    • BF Goodrich g-Force R1S
    View Complete Tire Selection
    Add tires to your FL-5 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
    California BAY AREA
    e30 M3, 335d
    FL-5 wheels look even better when wrapped in some nice wide tires.
    Dec 2007
    MD
    95 Avus, 96 XJ 4.6
    How about some 17x9.5 et35s for us e36 heads?
  1. ► APEX | SM-10 Lightweight Track Wheels
    By Eddy@ApexRaceParts in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: Today, 03:58 PM
  2. BBS RK lightweight track wheels - cheap
    By 96cosmosM3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-29-2006, 03:02 PM
  3. Lightweight track wheels
    By 96cosmosM3 in forum Race Cars & Track Parts
    Last Post: 08-02-2006, 10:31 PM
  4. looking for inexpensive/lightweight track wheels...Any ideas?
    By NY98M3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-04-2004, 11:05 AM
  5. Looking for inexpensive/lightweight track wheels....Any ideas?
    By NY98M3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-29-2004, 07:08 PM
