Results 1 to 4 of 4
Thread: Help identifiyng engine hose
    Middlesbrough England
    1999 E46 328CI Auto
    I have been having a misfiring problem on idle and my engine power is sometime erratic so replaced the plugs and coils after reading the ecu fault codes. This did not fix the problem so checked the hoses and found 2 had cracked or perished! 1 is the intake filter elbow attached to the air flow sensor and the 2 I have no idea what its called! can some 1 tell me the hose name? and tell me what problem this might cause? https://1drv.ms/f/s!AvKwA7ZfmQIpgQpK0e_ocq11ILeV
    You can see in the close up the hose has split!
    My car is a 328ci
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    Split hoses that are meant to carry air or ensure the lack of it cause vacuum leaks and throw the computers out of whack. I'd suggest getting on realoem.com with the last 7 digits of your VIN and look at the diagrams.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    The hose's name is James.
    1999 E46 328CI Auto
    I Went to my local BMW dealership with a photo as was told its the crank case ventilation hoses! £30 for the hose but told to replace all at a cost of £250. Did a search on ebay £58 for Febi/bilstein brand. Hopefully this fixes the misfire
  1. Replies: 0
    Last Post: 10-21-2014, 05:37 AM
  2. Help Identifying "Mystery Hoses" - Engine Bay Confusion
    By EThirtySicks in forum 1991 - 1999 (E36)
    Last Post: 08-13-2009, 03:56 PM
  3. 318i (M42 engine) hose question...
    By DDD in forum 1991 - 1999 (E36)
    Last Post: 05-22-2001, 12:13 AM
  4. help: check engine light
    By m3fanatic97 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 06:33 PM
  5. Please help....M3 engine making wierd niose!!!
    By Brandonb in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2001, 08:41 PM
