Results 1 to 8 of 8
Thread: 750Li "Engine too hot" before startup
    Sep 2016
    Phoenix
    E46 E39
    2012 BMW 750Li warning coming up as "Engine too hot drive moderately" before I even start my drive first thing in the morning.
    What gives???
    Probably one of the auxiliary water pumps has failed. You'll have to have someone read and scan the codes to get a hint at which one is bad.
    Sep 2016
    Phoenix
    E46 E39
    Quote Originally Posted by White94RX View Post
    Upon further reading from forums, seems to be the aux pump for the turbo. But, how many aux pumps are there?
    One for the turbo's, one for the intercoolers, another for the AC/heater, and certain cars have yet another for the auxiliary radiator.
    Sep 2016
    Phoenix
    E46 E39
    I had the code pulled and it shows turbo aux pump, which is the smaller pump. We replaced it, topped it off and started the car. Message still shows up.
    Any other tips?
    Bleed the system properly, clear the codes and see what happens. Hopefully you replaced the correct pump.
    Sep 2016
    Phoenix
    E46 E39
    No CEL. But, more advanced diagnostic tool shows turbo pump fault.
    Is it necessary to delete code or will it clear on its own since faulty part has already been replaced?
    You need to clear the codes.
  1. E90 n46b20 lights up "Engine too hot" (but water temperature is at norm)
    By abes777 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 04-12-2017, 04:02 PM
  2. AC Problems and Engine Too Hot - Related?
    By Hexemutze in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-25-2015, 01:43 PM
  3. Engine too hot light with Sound
    By Mr Arsenal in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-20-2013, 03:20 PM
  4. Does this labor quote look too high?
    By queens in forum 1988 - 1996 (E34)
    Last Post: 06-03-2009, 10:24 PM
  5. Plastic Cowl Behind Engine Disintegrated. Too Hot?
    By adapteruser in forum 1996 - 2003 (E39)
    Last Post: 01-10-2008, 06:57 AM
