Results 1 to 22 of 22
Thread: 95' M3 - Custom Complete Rear-end, LTWs, Smoked Tails - No Longer Available
    Oct 2008
    Centennial, CO: S'port, LA
    95 M3 - 03 325i - 68 Bug
    Have my 1995 M3 that is unfortunately being totaled by insurance after the transport carrier that was delivering it for me had an accident.
    Front End :
    Subframe w/welded reinforcement plates for motor mounts, powder coated speedboat aluminum to be easy to keep an eye for leaks/cracks/stress
    Euro coolant reservoir, lines, hoses, and mounting tabs. I will need to remove them, they're riveted into place. But I have removed rivets before, wouldn't be an issue. Only issue is I may keep the euro coolant overflow setup.
    Koni S/A shock setup with eibach springs, front strut bodies powdercoated White for ease of watching over bends, breaks, or leaks. And makes it a breeze when cleaning to look over things. In realty after looking over things, this setup has closer to around/less than 22k miles of use on it, as I changed it all right before coming back to Denver, which was about 6-8 months after the entire rear end build was done.
    New OE fender liners - SOLD
    Rear End :
    Subframe, upper control arms, and diff cover all powder coated speedboat aluminum(same as front subframe).
    Turner Motorsport rear adjustable camber arms.
    Koni S/A shocks with eibach lowering springs, 96-99 Upper Strut Hats for updated alignment angles, RE Rear shock mount reinforcement plates w/recently replaced bushings. I honestly don't think the new bushings have seen the road yet if Im remembering right.
    3.38 differential w/near 80-90k miles now since rebuild many many years ago. AKG solid diff mounts in diff cover. Was the perfect combination for not having any added NVH with using factory rubber bushings through the actual mounting hardware to the vehicle chassis(subframe, RTAs, etc.).
    RTAs have new wheel bearings, hubs, ball joints, and RTABs w/limiters as of around 30-40k miles ago. So they are not very worn at all. Did a complete rear end swap and changed bushings out when I did it so was all done at one time.
    Subframe bushings also have the same 30-40k mile range of use.
    Every thing was replaced OE BMW from thebmwminipartstore.com
    Would be awesome if somebody would grab the entire rear end as one complete unit, as that would be a bit easier to pallet and freight as one, or two big chunks. I do not mind shipping, but I will not entertain lowball offers with the fact I'll be packing and arranging shipment for you.
    Complete Rear End w/differential(30-40k miles) - $1,4k
    3.38 Rear Differential(80-90k miles on bearings and clutch packs) - $600 *shipped*
    S50/M50 Manifold - SOLD
    Rack Doctor ZHP R&P(30-40k miles) - SOLD
    5-Series Steering Coupler - SOLD
    Front Subframe w/reinforcements - $200 shipped
    E36-Coupe "BMW Motorsport" door handles, only 4yrs old or a little less. Don't waste time buying euro ones that are already brittle, and of the old metallurgy that is prone to snapping. - SOLD
    Koni/Eibach(fr),Dinan(rr)Suspension in AW powdercoated strut housings-RE Rear Shock Mount Reinforcement(22k or less miles) - SOLD
    LTW Wheels - 17x7.5 ; 17x8.5 - $800 PLUS shipping
    TMS adjustable camber arms - $200-shipped($300 new)
    Side Skirts - SOLD
    List Date: 5/1/2017
    For more info, click here to view the original listing: 95' M3 - Custom Complete Rear-end, LTWs, Smoked Tails
    This item is no longer available.
    Nov 2007
    Houston, TX
    1 Blue, 1 White, 1 Black
    Parting out interior bits by chance?
    Past: '99 Hellrot/Dove M3 | '97 S14 1JZ | '06 Triumph Daytona 675 | '01 330I M-Tech I | '99 Silvia S15 | Current: '96 Estoril/Black M3
    Instagram
    Oct 2008
    Certain bits I might be able to, just depends what you're after. Insurance basically wants it replaced with "something similar" if removed/kept. And I don't have to actually put it back on, just toss parts in the car they said.
    Nov 2007
    Houston, TX
    PM incoming.
    Instagram
    May 2009
    OC California
    1999 BMW 328is-M
    Willing to sell the rear ltw rims?
    Aug 2015
    Charlotte NC
    BMW E36 M3 Alpine White
    Could you pm me please ? Thanks ! Highly interested !
    Oct 2008
    I would like to try and sell the LTWs as set if I could, the typical 17x7.5(x2) and 17x8.5(x2). I'll load up better pics of the wheels, and likely make a separate FS ad.
    The lips received a little bit of rashing from the driver's carelessness, so I was going to be listing the set for $800. Tires aren't bad, but they'll serve as protection...and nothing has ever been repaired/reworked with these wheels either. Raw and original, in all of their glory.
    Jun 2013
    Houston, TX
    E36 M3 3.2, E90 328i
    Interested in two rear LTWs as well. Also interested in the door handles... are they smooth still or do they stay in the upward position? How much shipped to San Antonio 78254?
    Oct 2008
    They're still smooth, it may be the angle of my photo. I tried to hurry and get a few before I lost daylight.
    I would very much like to sell the LTWs as a set, as I just wouldn't have any use for the fronts. I typically have kept an eye for that unicorn-ad of the 2-8.5s for sale, but never came across it before this event happened.
    There will be a thread popping up for them soon, just trying to find some steelies to replace them with.
    Handles would do $250, taking into consideration I paid around $180/each coded to my vin....you'll have to slide your lock cylinders into place though. And the gaskets are definitely gone, now that the car has been sitting here since June 24th, when this fool delivered it smashed up.
    Jul 2016
    Nutley, NJ
    97 328is, 2018 X5
    Can you sell the side skirts if available?
    Under Hood: 98 S52 Swap | AA C38 stg 1 Supercharger| M50 manifold | UUC motor & tranny mounts | RK custom tune
    Drivetrain: 3.38 LSD | UUC stg 2 clutch | UUC 8.5 lb flywheel | Z3 steering rack | Complete M3 brake system | SS brake & clutch lines
    Suspension: KW v1 Coilovers | X-Brace | PowerFlex RTABS
    Exhaust:
    AA track pipe | AA Gen III Exhaust
    Exterior: All OEM - M3 front & rear bumper, M3 twisty side skirts, side mirrors, staggered contour wheels
    Misc: Euro G4 Ellipsoids-Ultra HD 60+ LED eyes | Euro 3-Spoke steering wheel | Magma Vader seats
    Oct 2008
    I could, I figure may kill a bit if heading to NJ.
    Was planning to ask $120+the shipping amount. PM me and we can discuss further, or give me an email and I'll get pics of them specifically.
    Oct 2008
    More pics coming
    Indianapolis, IN
    951, LTW M3, GTI
    Cant sell glovebox then? Is it black? Let me know thanks.
    Oct 2008
    It is, and it all depends if I can find one to replace it with.
    Literally can be wrong color, or junk. And I don't have to re-install!
    Oct 2015
    Alabama
    97 BMW M3 Sedan
    do you have the front speakers? i need a set of the housings for one side (Tweeter and Mids) Shipped to 36054 please pm. Thanks.
    Current
    -1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
    Past
    -2001 BMW 325i
    -1999 BMW M3 Vert White
    -1981 VW Rabbit Pickup (Caddy) 2.0 ABA
    "I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
    Oct 2008
    Let me check, as somebody might be taking the door panels complete.
    Side skirts sold
    Oct 2008
    Car is officially picked up by insurance as of 05/27/17
    Anything on the list is still for sale, or gladly being kept for my next one I'm going to snag.
    Jul 2012
    Herndon, VA
    98 M3/4/5, RIP 528e
    Oct 2008
    I do not. The exhaust had been removed and sold for some time now, so unfortunately that piece was never actually available with this part out.
    Sep 2014
    Cumming GA USA
    1995 M3 Alpine/Black 5sp
    Price on axles shipped to 30041?
    Oct 2008
    So the rear end is now going to be going on the replacement M3 I just drove back to CO cross country.
    I do apologize, but since everything is so fresh and still in almost new condition due to being more transport mileage than actual use...I'm going to swap it into the new car.
    Thank you for everybody's inquiries and purchases, but with what is left, I can just keep on using until broken since I know a lot of folks rather have new than buying partially-used.
    Oct 2008
    Shipping on the rear end is $250 Freight
  1. E36 93 alpine white coupe part out. black interior/m3 interior
    By 3xxtiMZK2 in forum Whole Parts Cars
    Last Post: 10-21-2010, 01:32 AM
  2. NJ 93 alpine white coupe part out. black interior/m3 interior
    By 3xxtiMZK2 in forum New York / New Jersey / Connecticut
    Last Post: 09-29-2010, 08:05 PM
  3. 95 alpine white 540i part out
    By bizob in forum E34 Classifieds (closing soon)
    Last Post: 05-02-2010, 01:32 PM
  4. 95 M3 Alpine White 5 Speed 71k Miles
    By sportcarm3 in forum BMW Cars For Sale / Wanted
    Last Post: 11-15-2004, 10:11 PM
  5. FS: 95 M3, Alpine white/Dove gray, 94k miles, $15k. CA. Los Angeles.
    By southsails in forum BMW Cars For Sale / Wanted
    Last Post: 01-28-2004, 11:27 PM
