95' M3 - Custom Complete Rear-end, LTWs, Smoked Tails
Have my 1995 M3 that is unfortunately being totaled by insurance after the transport carrier that was delivering it for me had an accident.
Front End :
Subframe w/welded reinforcement plates for motor mounts, powder coated speedboat aluminum to be easy to keep an eye for leaks/cracks/stress
Euro coolant reservoir, lines, hoses, and mounting tabs. I will need to remove them, they're riveted into place. But I have removed rivets before, wouldn't be an issue. Only issue is I may keep the euro coolant overflow setup.
Koni S/A shock setup with eibach springs, front strut bodies powdercoated White for ease of watching over bends, breaks, or leaks. And makes it a breeze when cleaning to look over things. In realty after looking over things, this setup has closer to around/less than 22k miles of use on it, as I changed it all right before coming back to Denver, which was about 6-8 months after the entire rear end build was done.
New OE fender liners - SOLD
Rear End :
Subframe, upper control arms, and diff cover all powder coated speedboat aluminum(same as front subframe).
Turner Motorsport rear adjustable camber arms.
Koni S/A shocks with eibach lowering springs, 96-99 Upper Strut Hats for updated alignment angles, RE Rear shock mount reinforcement plates w/recently replaced bushings. I honestly don't think the new bushings have seen the road yet if Im remembering right.
3.38 differential w/near 80-90k miles now since rebuild many many years ago. AKG solid diff mounts in diff cover. Was the perfect combination for not having any added NVH with using factory rubber bushings through the actual mounting hardware to the vehicle chassis(subframe, RTAs, etc.).
RTAs have new wheel bearings, hubs, ball joints, and RTABs w/limiters as of around 30-40k miles ago. So they are not very worn at all. Did a complete rear end swap and changed bushings out when I did it so was all done at one time.
Subframe bushings also have the same 30-40k mile range of use.
Every thing was replaced OE BMW from thebmwminipartstore.com
Would be awesome if somebody would grab the entire rear end as one complete unit, as that would be a bit easier to pallet and freight as one, or two big chunks. I do not mind shipping, but I will not entertain lowball offers with the fact I'll be packing and arranging shipment for you.
Complete Rear End w/differential(30-40k miles) - $1,4k
3.38 Rear Differential(80-90k miles on bearings and clutch packs) - $600 *shipped*
S50/M50 Manifold - SOLD
Rack Doctor ZHP R&P(30-40k miles) - SOLD
5-Series Steering Coupler - SOLD
Front Subframe w/reinforcements - $200 shipped
E36-Coupe "BMW Motorsport" door handles, only 4yrs old or a little less. Don't waste time buying euro ones that are already brittle, and of the old metallurgy that is prone to snapping. - SOLD
Koni/Eibach(fr),Dinan(rr)Suspension in AW powdercoated strut housings-RE Rear Shock Mount Reinforcement(22k or less miles) - SOLD
LTW Wheels - 17x7.5 ; 17x8.5 - $800 PLUS shipping
TMS adjustable camber arms - $200-shipped($300 new)
Side Skirts - SOLD
List Date: 5/1/2017
For more info, click here to view the original listing: 95' M3 - Custom Complete Rear-end, LTWs, Smoked Tails
This item is no longer available.
Parting out interior bits by chance?
Past: '99 Hellrot/Dove M3 | '97 S14 1JZ | '06 Triumph Daytona 675 | '01 330I M-Tech I | '99 Silvia S15 | Current: '96 Estoril/Black M3
Certain bits I might be able to, just depends what you're after. Insurance basically wants it replaced with "something similar" if removed/kept. And I don't have to actually put it back on, just toss parts in the car they said.
PM incoming.
Willing to sell the rear ltw rims?
Could you pm me please ? Thanks ! Highly interested !
I would like to try and sell the LTWs as set if I could, the typical 17x7.5(x2) and 17x8.5(x2). I'll load up better pics of the wheels, and likely make a separate FS ad.
The lips received a little bit of rashing from the driver's carelessness, so I was going to be listing the set for $800. Tires aren't bad, but they'll serve as protection...and nothing has ever been repaired/reworked with these wheels either. Raw and original, in all of their glory.
Interested in two rear LTWs as well. Also interested in the door handles... are they smooth still or do they stay in the upward position? How much shipped to San Antonio 78254?
They're still smooth, it may be the angle of my photo. I tried to hurry and get a few before I lost daylight.
I would very much like to sell the LTWs as a set, as I just wouldn't have any use for the fronts. I typically have kept an eye for that unicorn-ad of the 2-8.5s for sale, but never came across it before this event happened.
There will be a thread popping up for them soon, just trying to find some steelies to replace them with.
Handles would do $250, taking into consideration I paid around $180/each coded to my vin....you'll have to slide your lock cylinders into place though. And the gaskets are definitely gone, now that the car has been sitting here since June 24th, when this fool delivered it smashed up.
Can you sell the side skirts if available?
Under Hood: 98 S52 Swap | AA C38 stg 1 Supercharger| M50 manifold | UUC motor & tranny mounts | RK custom tune
Drivetrain: 3.38 LSD | UUC stg 2 clutch | UUC 8.5 lb flywheel | Z3 steering rack | Complete M3 brake system | SS brake & clutch lines
Suspension: KW v1 Coilovers | X-Brace | PowerFlex RTABS
Exhaust: AA track pipe | AA Gen III Exhaust
Exterior: All OEM - M3 front & rear bumper, M3 twisty side skirts, side mirrors, staggered contour wheels
Misc: Euro G4 Ellipsoids-Ultra HD 60+ LED eyes | Euro 3-Spoke steering wheel | Magma Vader seats
I could, I figure may kill a bit if heading to NJ.
Was planning to ask $120+the shipping amount. PM me and we can discuss further, or give me an email and I'll get pics of them specifically.
More pics coming
Cant sell glovebox then? Is it black? Let me know thanks.
It is, and it all depends if I can find one to replace it with.
Literally can be wrong color, or junk. And I don't have to re-install!
do you have the front speakers? i need a set of the housings for one side (Tweeter and Mids) Shipped to 36054 please pm. Thanks.
Current
-1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
Past
-2001 BMW 325i
-1999 BMW M3 Vert White
-1981 VW Rabbit Pickup (Caddy) 2.0 ABA
"I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
Let me check, as somebody might be taking the door panels complete.
Side skirts sold
Car is officially picked up by insurance as of 05/27/17
Anything on the list is still for sale, or gladly being kept for my next one I'm going to snag.
Do you have both of the metal muffler hanger supports available?
Part number 18207839657
I do not. The exhaust had been removed and sold for some time now, so unfortunately that piece was never actually available with this part out.
Price on axles shipped to 30041?
So the rear end is now going to be going on the replacement M3 I just drove back to CO cross country.
I do apologize, but since everything is so fresh and still in almost new condition due to being more transport mileage than actual use...I'm going to swap it into the new car.
Thank you for everybody's inquiries and purchases, but with what is left, I can just keep on using until broken since I know a lot of folks rather have new than buying partially-used.
Shipping on the rear end is $250 Freight
