Page 5 of 37 FirstFirst 12345678910111213141530 ... LastLast
Results 101 to 125 of 904
Thread: M50 turbo build
  1. #101
    Apr 2017
    Florida
    E36
    Sweet, Lord knows I need all the help I can get.
    any info to share on oil return for top mount set up?
  2. #102
    Virginia
    97' m52 turbo
    Quote Originally Posted by Thompson501 View Post
    not extremely familiar with top mount or where the guys return too.
    Easiest with no tapping would be to replace one of the 2 vanos sprocket bolts with bolt that has a flange on it with rubber/ or whatever hose
    if not youll have to tap oil pan.
  3. #103
    Virginia
    97' m52 turbo
    something like this, maybe
    to here:
    Would be easiet route if you dont want drop subframe and drill pan. Not sure how high the turbo would sit but u could always run a $60 scavenge pump
  4. #104
    Jul 2004
    Austin, TX
    AA turbo 332i
    M50 turbo build
    Another tip, you can use the newer exhaust mani studs from n54 335i etc as they are shorter, have an etorx head on the tip and will give you so much more room to work! I also used ball bearings in the holes because I felt they were going on too deep for nice thread engagement.
    And please don't compromise on oil return!!! Little less critical for top mount with gravity on your side but personally I cheaped out, short-cutted and installed junk that leaked and then had to later pull the oil pan and replace with a welded -an fitting while on my back using jack stands. You really want that part bulletproof
    Also saw someone that tapped the timing cover for oil drain but did not look deep into that solution because I'm bottom mount.
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  5. #105
    Apr 2017
    Florida
    E36
    Mani studs complete last night , many hours, lol
    i will continue researching oil return on top mount before doing anything. Options are nice if they will work correctly
    those 2 blot/plugs would be sweet if they work with top mount
    Virginia
    97' m52 turbo
    looks and appears to be high enough to use gravity to one of those bolts.
    I use the bolts from bottom mount with 2 scavenge pumps and a check valve with no smoking issues
  7. #107
    Apr 2017
    Florida
    E36
    Interesting, that would be nice
  8. #108
    Nov 2013
    Hager City, WI, USA
    1994 BMW 325is Coupe
    I've been boosted for a couple years. Just do a .140mls with arp studs and you'll be good. Haven't read all the comments yet, so not sure on your power goals. But you'll be safe on 400whp on that. Piss pounded mine on 400whp with an hx35, 60lb injectors on Miller. and never missed a beat. I'm on e85 and an s366 now on just a stock motor with head gasket and studs and again never missed a beat tuned on stock dme by a good buddy of mine and blew tires off until rev limiter in 3rd gear.lol I feel just a head gasket and studs is just a necessity for boost applications at all. The stock blocks are tough little bastards
  9. #109
    Apr 2017
    Florida
    E36
    Appreciate the feedback
  10. #110
    Apr 2017
    Florida
    E36
    Crazy Question, does powder coating hold up on these valve covers?
  11. #111
    Apr 2017
    Florida
    E36
    Looks like I'm gonna move forward with Nick instead of Zach just being Nick is 10 minutes away from me and is able to provide the tune
    hopeful to install arp bolts, fuel pump, and oil feed this coming week.
    multi confirmations on oil return to pan train plug being top mount turbo.
    sounds like this 6266 might be a little large and slow to spool, (4000 rpm?)
    any feed back on the spool at 4000 rom
  12. #112
    Apr 2006
    Minnesota eh?
    86 325es
    It is pretty big for a 2.5. I would expect it to start making boost at 3000 and probably 15 lbs by 4000.
  13. #113
    Apr 2017
    Florida
    E36
    gotcha,
    would you suggest trying to exchange? For what size?
    or do you think it will work ok
  14. #114
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I would keep the 6266. It may be too big for you now but it won't be later. I wish I bought a big turbo from the beginning....
  15. #115
    Manchester, N.H.
    96 332IS 6466 turbo
    gotcha,
    6262 with a small back housing will be good. In my opinion a 6266 is too big for 2.5 L. Maybe even a 5858 for 2.5L.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  16. #116
    Apr 2017
    Florida
    E36
    Gotcha, might be a challenge being that i didn't purchase directly.
    precision stated it will be good for future goals when motor work is done
  17. #117
    Manchester, N.H.
    96 332IS 6466 turbo
    6266 will most likely hit 15# by 4400-4800 with a 2.5L. Its a big turbine wheel for small displacement. If that was my car I would look for bigger displacement or smaller turbo. Maybe 2 steps smaller. Personally I feel a 58-60mm compressor with a 58-62mm turbine wheel would be a way better choice.
    Sell the 6266 to someone with a 3.0-3.2L.
    Now if you revved to 8k+ then the 6266 might be a good choice.
    1996 332IS
    Built 3.2
  18. #118
    Apr 2017
    Florida
    E36
    The smaller set up would hit at what rpm range?
    the major difference of the size is WHEN the turbo starts to spool and create power?
  19. #119
    Apr 2017
    Florida
    E36
    Crap!
    arp studs arrived and ready to install tonight!
    do I need arp thread chaser?
    will spaying brake cleaner be good?
    i do have the arp ultra torque lub for studs to receive nuts
  20. #120
    Feb 2012
    1995 BMW M3
    I just cleaned the threaded holes with brake clean. Your fine.
  21. #121
    Apr 2017
    Florida
    E36
    Kool
    thank you
  22. #122
    Apr 2017
    Florida
    E36
    Has anyone ever installed Arp studs with cams in place?
    I don't see the arp washers fitting through the cam cradle housing (not sure on the correct term)
    any feedback appreciated
  23. #123
    Feb 2012
    1995 BMW M3
    I tried. Had to remove the cam trays unfortunately.
  24. #124
    Apr 2017
    Florida
    E36
    I don't see the washers fitting with out removing trays as you stated
  25. #125
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Yes. I did with schrick cams years ago. Had to grind down a socket or two for clearance. This was in 2007 or 8. Maybe the nuts were smaller then but I cannot remember for sure.
  1. e30 m50 turbo build
    By So Live in forum Forced Induction
    Last Post: 04-09-2014, 09:26 PM
  2. e30m3 junkyard m50 turbo build!
    By scooter3k in forum Forced Induction
    Last Post: 04-19-2012, 07:46 PM
  3. euro 2.5 m50 turbo build
    By ADAMOD in forum Forced Induction
    Last Post: 03-20-2011, 05:16 AM
  4. euro m50 turbo build.
    Last Post: 04-20-2010, 07:51 AM
  5. My unofficial M50 Turbo build thread
    By bimmerguy2582 in forum Forced Induction
    Last Post: 05-15-2009, 05:16 PM
