Page 4 of 37 FirstFirst 123456789101112131429 ... LastLast
Results 76 to 100 of 904
Thread: M50 turbo build
  1. #76
    Jul 2004
    Austin, TX
    AA turbo 332i
    Nice looking car, keep it up! And yeah these guys are absolutely correct... pay now vs cheap out now and pay more later!!
    I'm still sorting issues on a 3 year old "budget build" but enjoying it every day.
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  2. #77
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by rajicase View Post
    I am indeed 23. Started the build when I was 22. That guy you built a 600hp e36 for must be more responsible than I was when I was in my teens. I would have killed myself ..
    Vancouver has the most supercars of any other city in North America and 95% of them have new driver decals on the back of them. Lamborghinis, McLarens, Ferraris etc are littered everywhere you look. What are these kids going to move up to once they learn how to drive?
  3. #78
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    Wtf
    I wish daddy would have bought me a lambo when I was 16 !
  4. #79
    '97 M3
    They are also given millions to buy up local real estate. A crappy tear down in Vancouver is 1.5 million dollars because of it.
  5. #80
    Manchester, N.H.
    96 332IS 6466 turbo
    Question , is your head split in 1/2 ?
    Have you ever met the queef sisters ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  6. #81
    Mar 2016
    Australia
    e30 318i, 135i
    lol
  7. #82
    Apr 2017
    Florida
    E36
    any tuners to recommend in south Florida?
  8. #83
    Apr 2017
    Florida
    E36
    Good looking car as well
    hooeful to start this venture this weekend at the house
  9. #84
    '97 M3
    NickG is in Florida. He would be the most experienced tuner for turboed e36's.
  10. #85
    Apr 2017
    Florida
    E36
    OKthank you, is anyone running AC or delete? Has anyone used the CX for the intercooler kit
  11. #86
    Apr 2017
    Florida
    E36
    IMG_0507.jpg Decided to try to keep ac. This good help keep the wife in the game.
    i knotched the aluminum bumper support and mounted directly through top surface of supporting . Between fan and bumper is tight but some knotching on bumper worked. I will need to relocate ac dryer on hot side for piping. The cx piping is not correct but the modification should be worth keeping ac, if possible. Got all header nuts off, fun, lol.
    one slight issue, intercooler hangs below bumper 1.5 inch, comment please
  12. #87
    Virginia
    97' m52 turbo
    Quote Originally Posted by Thompson501 View Post
    <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=600047"/> Decided to try to keep ac. This good help keep the wife in the game.
    Kept ac, cold piping under sub frame. Only way really
    Not sure where the mounting points on your IC are but take it back off and use the bumper as a reference point and then fabricate brackets or install.
  13. #88
    Apr 2017
    Florida
    E36
    Mounting points are on top and bottom, no good as is?
    any pics available on your piping?51647467770__38FE4F44-2B65-4B45-85EA-493A80C48522.jpg51647452524__15F3253A-2C40-4567-A536-F3A2CFE3C3AA.jpgjust a dry run
  14. #89
    Virginia
    97' m52 turbo
    Yes, go to my thread:
    https://www.bimmerforums.com/forum/s...52-Turbo-Build
    Didn't realize you were going top mount though, so your piping will be different.
    I removed the AUX fan and installed a slim line fan behind radiator, gave me plenty of IC room up front.
  15. #90
    Apr 2017
    Florida
    E36
    Gotcha, I will add brackets from the bottom IC mounts to the bumper mounts as well
    Appreciate feedback
    need to change some studs for exhaust , use lock tight? These studs do not bottom out correct
    i gonna try to button up the ex manifold tonight
  16. #91
    Virginia
    97' m52 turbo
    Appreciate feedback
    Why is not bottoming out? Stripped?
    Try anti seize lube on threads. I personally wouldn't use loctite on exhaust studs
    Somers if you get the bolt started and start tightening down the sruds will follow
  17. #92
    Apr 2017
    Florida
    E36
    Some of the studs came out, I purchased new studs. I am going to double nut and install the studs tonight. Do you know when installing the new studs, Will they eventually bottom out and stop threatening in? Wanted to make sure that I did not go too far in with the studs and damage something internally. From what I read regarding the gaskets, metal side against the head, is that what you have heard
    X pattern working from the center out is the correct way to tighten manifold?
  18. #93
    Virginia
    97' m52 turbo
    What mani do you have there all made different. Tightening the spa was a pain, didn't follow a pattern for it, no leaks.
    Damage something eternally not sure what you mean here. You want the threads to be snug. And tightening hex bolt should tighten thread some.
    If I were you I would use bolts instead may work better for your situation
  19. #94
    Apr 2017
    Florida
    E36
    The mani is rapidspool and is a pain as well
    bolts won't work, gonna install new studs where needed
    how's your build going
  20. #95
    Virginia
    97' m52 turbo
    Not terrible actually,
    Got injectors in yesterday, waiting to install meth kit. Ordered a couple exhaust parts so I can start welding. Waiting on funds for engine management/tuning.
    FYI, it took me 7-9 hours to install my exhaust manifold. So I would assume the difficulty you are having is considered normal while installing these manifolds with the head on the block.
    persistence + beer = success
  21. #96
    Apr 2017
    Florida
    E36
    Have you decided on what tune
  22. #97
    Virginia
    97' m52 turbo
    22rpd
  23. #98
    Apr 2017
    Florida
    E36
    Spoke with Zach with 22rpd, sounds like a good fit for me
  24. #99
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    Zach's a good guy, he was a tremendous help with my build.
  25. #100
    Virginia
    97' m52 turbo
    Quote Originally Posted by mboor View Post
    Yes he seems to be.
    Thing that stood out to me about him is that he contacted me, I didn't have to contact him.
    Good communication is must
  1. e30 m50 turbo build
    By So Live in forum Forced Induction
    Last Post: 04-09-2014, 09:26 PM
  2. e30m3 junkyard m50 turbo build!
    By scooter3k in forum Forced Induction
    Last Post: 04-19-2012, 07:46 PM
  3. euro 2.5 m50 turbo build
    By ADAMOD in forum Forced Induction
    Last Post: 03-20-2011, 05:16 AM
  4. euro m50 turbo build.
    Last Post: 04-20-2010, 07:51 AM
  5. My unofficial M50 Turbo build thread
    By bimmerguy2582 in forum Forced Induction
    Last Post: 05-15-2009, 05:16 PM
