I definitely want to avoid any rattling.
OE dmf and fx stage 4 will result in zero rattle and an OE pedal feel and engagement.
Yes it is.
Which helps spool up your turbo and doesn't rattle at all.
How bad do they rattle, the let? Very noticeable
Sent from my SAMSUNG-SM-G935A using Tapatalk
It varies from car to car. Thicker gear oil in the trans helps for some. Increased idle speed can also help.
But I find gear rattle to be one of the most obnoxious sounds. Seriously sounds like someone tossed a bucket of bolts in your oil pan. Sounds like your car is falling apart..
I have an 11lb flywheel and there is noticeable gear rattle at idle. Mine sounds like a metallic version of a baseball card in a bicycle wheel. The thing that I don't like is the stiff engagement. Next time around I will try a dual mass flywheel.
It looks like the tachometer is moving in sequence as far as miles per hour and RPMs. I believe when the wastegate is open I feel some loss of power
I don't think it's the tire slipping or the clutch
Seems more noticeable in fourth and fifth gear
The boost controller saying 6 1/2 pounds I might play with it a little bit and start bringing it up slightly
Vf sc is ??
i am going to review direction on boost control and figure out how to
with a 7 lb spring should the boost control be able to increase over 7 lb?
after running a closed wastegate, I have been cautious
If he plans to run more boost he should probably upgrade clutch anyway?
Yes I definitely plan on upgrading the clutch
Am I correct that the boost controller should be able to allow me to run more boost then what the wastegate spring is, example 7 pounds spring
Yes, the spring is minimum amount of boost you can rub. Controller will let increase it
I thought so
i have to work on it
any one have a cheat sheet, lol
greddy pros b 11
Yes, consider the Wastegate spring a starting point and use bc to go up. Not sure what you have but some units will change boost levels for different rpms, gears, etc...
Read the manual for your controller can probably be found on their website
Will do
I believe I made some positive adjustments on boost control
sunday morning before church, we will see
Nice to see you got it put together so quickly and boosting.
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Mr Rapidspool!
im the guy that you called back on Mother's Day after I said you sent wrong mani, you informed me that the turbos rotate.
build went well!
Very happy with your top mount mani!!! Nice product
thank you again for your great customer service!!
i
Good video! Amazing how the sound of the engine changes when these motors see boost. They sound alive
Ever get your ignition problem fixed ?
Yes it has a beautiful sound, the E 85 is awesome with that for 3 inch exhaust
was the alternator so I am good now actually went with the larger size producing more current as well
Yes it has a beautiful sound, the E 85 is awesome with that for 3 inch exhaust was the alternator so I am good now actually went with the larger size producing more current as well
In a hurry to get to church I see! Awesome build, congrats on the hard work. I'm also a total noob when it comes to boost but plan on it in the future.
