Page 36 of 37 FirstFirst ... 11262728293031323334353637 LastLast
Results 876 to 900 of 904
Thread: M50 turbo build
  1. #876
    Oct 2012
    Saint Paul, Minnesota
    87 BMW E30 w m50
    Quote Originally Posted by Butters Stoch View Post
    Its not really necessary....... BUT........ If your running E85 then your going to be running at least a walbro 450/485 maybe 2 pump, those 2 pumps will overpower your stock regulator like a bastard. So, your base fuel pressure will be much higher than the stock 51 @ 0 vac. This becomes a problem if your relying on buying a tune from (xxxxxx). There will need to be adjustments because of it. Idle/part throttle fuel trims the car will be pulling fuel due to a rich condition, you will be looking adaption codes till the tuner adjusts injector pulse widths. So, to make things easier, we buy these cool looking adjustable FPR's , mount them on the strut tower, and then we as the user can kinda tweak the tune a little ourselves.
    #thatswhywedothings.
    Sent from my E6782 using Tapatalk
    Gotcha, thats helpful. so basically to do it right on E85 I'd need to collect:
    -Walbro 450 pump, one in tank be sufficient? or you saying I should have an inline as well?
    -larger injectors - would siemens deka 80lb be large enough? they are about 875cc
    -Aftermarket FPR, any recommendations that don't break the bank?
    I'm already on ARP's just with stock compression. Original plan was sub 10psi on stock compression this year, I've seen alot of people have good results with that. currently have 42lb bosch injectors for that. Then do the CES spacer + cutring next year and raise up to 13-15 and probably invest in a ZF at that point.. its just a summer weekend car I like to tool around in... But now you guys are getting me thinking I should do E85 and skip the spacer + cutring... I'll ponder on it
  2. #877
    Apr 2017
    Florida
    E36
    I’m running aeromotive 340 lph, only 1 in tank,Deka 60 lb (I believe, provided with tune)great tune I might add!!. Don’t recall fpr ( car in shop having cage fab)
    i lack the experience but the arp+ E85 has been incredible. I had the boost at all kinds of level, even in the 20s when I had the wastegate lines incorrect, lol. Currently 12 pounds and focused on handling and traction
    what motor and turbo for your build? Top/btm?
  3. #878
    Oct 2012
    87 BMW E30 w m50
    Quote Originally Posted by Thompson501 View Post
    Top mount. motor is an M50b25tu. same as yours I believe. Turbo is a garret t3/t4 57 trim. I'm in an e30 chassis tho! I don't have any Nick G around me tho, so I'm doing a self tune on megasquirt for now.. And I found a guy about 40 mins away who can tune a megasquirt system.
    But I'm in the cities so e85 is everywhere around here, seems like that might be a better route for me and I might not even have to bother with the Headgasket for my goals... I don't really want more than 450whp in my e30.. I think that would be too much.. Ideally close to 350-400max and I'd be very happy to just enjoy it. Just fabricated up the downpipe a couple days ago, its coming along.
  4. #879
    Apr 2017
    Florida
    E36
    350-400 is plenty!
    i like the e30, maybe my next build, lol
    do you have a build thread, pics?
    do the E85, the fuel upgrades are well worth the benefits
  5. #880
    Jul 2010
    South Florida
    86 ETA Sport 2.7i
    Quote Originally Posted by SirMaxximus View Post
    How far are you from Warsaw Indiana? My business partner recently moved back there (well, recent as in last Sept lol). Anyways, we have had thousands of dyno tuning hours on MS and classic BMW's. e30 and e36. Bit of a haul for you, but you know it will be done right We even run turbo on stock 1995-earlier ECU's all the time in a live situation. The Motronic ECU is a bit of an anomaly so remote tuning is a bear, but I have dozens of them daily driving with +1 atmosphere much like Thompson.
    I might not be a Nick-g, but have a pretty good grasp on mapping and manipulating chip files... started messing with Motronic 3.x in 2011, been hacking prom chips since 06
    Wide Open Throttle Technologies, FL
    -John
    Instagram
  6. #881
    Jul 2010
    South Florida
    86 ETA Sport 2.7i
    Running a stock ECU I tuned, this stupid little 2.5 is making 177 whp on a stock 270 k mi 2.5l m50.
    -John
    Instagram
  7. #882
    Oct 2012
    87 BMW E30 w m50
    Quote Originally Posted by ForcedFirebird View Post
    I'm about 8 hours from warsaw. I'm already committed to MS. I picked up a MSpro PNP already!
    350-400 is plenty!
    Build thread is here:
    https://www.r3vlimited.com/board/sho...d.php?t=418730
    I spent alot of time on r3v so it made sense to start my thread there... altho it seems like I'm finding more info for my particular application on this forum
  8. #883
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    This is probably what I'm going to go with too. I love how sometimes e85 is cheaper than 87 here, even with ~25% efficiency loss.
  9. #884
    Apr 2017
    Florida
    E36
    Looking good, keep making progress
  10. #885
    Oct 2012
    87 BMW E30 w m50
    Quote Originally Posted by hotdish View Post
    minnesota aye? I'm in Saint Paul
    Thanks mate! Appreciate your help and documenting! Anyone has any recommendation on a particular FPR set up I'd love hear... I assume the whole fuel rail has to be replaced since the stock regulator is in the rail.
  11. #886
    Apr 2017
    Florida
    E36
    I believe they block off the fpr hole. New rail I don’t think is necessary
  12. #887
    Apr 2006
    Minnesota eh?
    86 325es
    minnesota aye?
    I'm up by Brainerd.
  13. #888
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    minnesota aye? I'm in Saint Paul.
    I'm in the suburbs south of minneapolis.
  14. #889
    Oct 2012
    87 BMW E30 w m50
    Sweet!
    I'm up by Brainerd.
    Woooh, local turbo boys! Yea I lived in South Minneapolis for a bit. Right above lake Hiawatha on 43rd.
    Someguy2800 I might pick your brain on Megasquirt settings once I get to that point. I've never done a full standalone before but I was interested in giving it a try and learning some things along the way
  15. #890
    Apr 2006
    Minnesota eh?
    86 325es
    Send me a PM. The company I work for is in Eden prairie so I get down there from time to time .
  16. #891
    Apr 2017
    Florida
    E36
    Hope everyone is good!
    missing my build, cage is moving along nicely
    Hopeful to be back on the track at the end of the month 39B38661-1496-47A6-9052-51EB0E6804FA.jpg
  17. #892
    Virginia
    97' m52 turbo
    Looks good man!
    Was it requirement for you to install a cage or did you just want piece of mind?
  18. #893
    Apr 2017
    Florida
    E36
    thanks, both piece of mind and will be required
  19. #894
    Mar 2017
    NJ
    e36 325ic
    wow this was a good read, lots of good information in here!
  20. #895
    Apr 2017
    Florida
    E36
    Glad you enjoyed, it was a great journey
  21. #896
    Virginia
    97' m52 turbo
    This is such a good thread
  22. #897
    Apr 2018
    Nassau Bahamas
    1994 BMW 325i Covertible
    lol
  23. #898
    Apr 2017
    Florida
    E36
    F0603D23-C6A6-4977-9ADA-5AD134B5330D.jpgMaking progress, adjusting ride height and corner balance next. Track night 5/8/18
  24. #899
    Apr 2017
    Florida
    E36
    Hope everyone is well!
    next chapter, lol
    lost compression on cylinder 6 on first day back at track, I think it took place when I missed a gear. It was fun when it lasted
    ready to have the S50 built
    looking to make as reliable as possible for road coarse
    undecided on power goals, 450 -550 should be plenty for road coarse
    some suggest NA for road coarse
    feedback In always appreciated
  25. #900
    Virginia
    97' m52 turbo
    Money Shift?
  1. e30 m50 turbo build
    By So Live in forum Forced Induction
    Last Post: 04-09-2014, 09:26 PM
  2. e30m3 junkyard m50 turbo build!
    By scooter3k in forum Forced Induction
    Last Post: 04-19-2012, 07:46 PM
  3. euro 2.5 m50 turbo build
    By ADAMOD in forum Forced Induction
    Last Post: 03-20-2011, 05:16 AM
  4. euro m50 turbo build.
    Last Post: 04-20-2010, 07:51 AM
  5. My unofficial M50 Turbo build thread
    By bimmerguy2582 in forum Forced Induction
    Last Post: 05-15-2009, 05:16 PM
