When a coil on plug gets the fire signal from the computer, what strength signal is it?
In other words, since a coil on plug is a mini-coil and needs electricity to charge and then discharge spark to the spark plug on signal, what kind of trigger signal makes that happen?
I'm wondering if a small magneto or Hall Effect sensor would work to send such signal to fire a coil on spark plug ignition, instead of a Motronic cumputer sending such (This for a non-automotive project.)
Its a low voltage pulse. The coil gets a ground and 12v and the trigger is a low voltage but im not sure if a Hall effect would work as it wouldnt allow a proper dwell time. Youd be better off using an old distributor coil. The spark when the ground is disconnected and charge when its connected so a momentary switch or a driver circuit and relay would work.
It's not a signal as so much as it is a loss of a signal, read up on induction coils. Also all you need is an o-scope to measure what your looking for.
https://www.youtube.com/watch?v=UEmSFDn8Rlw
If you really want to use a hall type setup just use one of the common 7 pin ignition amplifiers with a normal coil.
No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
Coils charge continuously as the other cylinders are going through the combustion cycle. The coil then discharges on command of the ECU through the remaining wire that you have identified.
The OP is asking for a non motoring application. Sounds like he just wants a spark on demand
