RM European Auto Parts
Results 1 to 15 of 15
Thread: Bricked DME 2005 E60 MS45.1
    Salt Lake City Utah USA
    1995 318i
    It will be great if a member can help me. My DME got damaged by water. After doing some reading there are some alternatives.
    1.- Transplant: Flash 29BL802, and EEPROM 95320W3 to used good working DME. Is this possible, what tools do I need? Does it need to be reprogrammed?
    2.- Use BDM to clone to a good used DME. What is BDM or wich is the one to get. Is this true?
    3.- Send it to be repaired to somebody else. What is the cost, what needs to be sent?
    Everything works on the car but it wont start. INPA does not list the DME under UIF list, it does not communicate with the DME either. I can read all the other modules.
    Attached photos of DME board, Outside DME Case, UIF Report.
    Thanks in advance for your time.
    Attached Files Attached Files
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Was your issue resolved?
    88M3 AW 43k miles Project FS
    Jul 2004
    Houston, TX
    36 Cylinders
    Is this the one damaged by water?
    I see a burned coil driver instead.. not so much water.
    1. This method should work, but you have to know what you're doing while soldering, and to make sure your research is complete, or else you'll have trouble. Technically it will work (even without programming after), but is risky to original dme and replacement.
    2. BDM will do it, yes. If you are looking to do this yourself, you have a lot of research ahead of you. It will require the bdm tool, bdm frame, bdm spring pins, and some harnesses for powering up the DME. But the DME circuits need to be functional.
    3. If your original DME does not work at all, yes, you will need to have someone match the replacement MS45 DME to your car's CAS system.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    1995 318i
    Tanks for your replies.
    328 Power 04:
    1. I have removed chips like the external flash (AM29BL802CB). I use a Hot Air Station. Do you think it will work with MS45.1?, they say is different from MS45.
    2. I just got the BDM100 Tool(clone). It came with an Italian program (SimSports). I do not see the Siemens MS45.1 or MS45 option. Do you know which is the Program I should use? Can the cable leads be Soldered directly to the DME Pads?
    Thanks.
    Jul 2004
    Houston, TX
    36 Cylinders
    You can solder directly to dme pads if you want yes.
    I am not sure about BDM100, as I use an older Galletto v54 I have. I just choose the Motorola profile for the processor on the board (MCxx or MPCxx CPUs).
    You should not mix MS45.1 with MS45.0. They are different yes. Slightly different programming too. They are easy to find, so get the one that came for your car so you don't run into trouble.
    -Abel
    1995 318i
    I have already read the files from the ECUs and CAS. It will be great if THE ISN from the Good used ECU be inserted in the CAS2 of the car. Here are the files, please change the extension from "pdf" to "rar"
    1995 318i
    Here is the CAS Eeeprom file that was not included in previous post. Please change the extension from "pdf" to "rar". Thanks.
    Jul 2004
    Houston, TX
    36 Cylinders
    Your files that you read with BDM do not look right. Some strange scrambling going on. (yes I renamed to rar, and extracted)
    -Abel
    1995 318i
    All of them?
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, all internal and external flash.
    Example, the data at offset 0x1F920 of your external should say "REGENSBU" in ASCII. Also right after it should have version description, hardware numbers, ecu type, in ASCII text. Yours is completely scrambled. Original "bricked" and replacement.
    Something is not right with your read.
    -Abel
    1995 318i
    Thanks. I will read them again tomorrow. Maybe I should tick off "encryption". Lets see what happens
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Damned North Korean hackers...........
    They really want you to tick off the encryption, because it really goes nuts when it's ticked off.
    Next thing you know, it'll be swapping your data at offset from Regensbu to Ox1F920 in ASCII. Then you'll have to pay a ransom to get your data back, and they'll use your money to pay for more missiles.
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    Haha!!, I laughed.
    -Abel
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    I'm gonna come and revisit the thread when you guys start speaking English again.
    1995 318i
    Just an update. 328 Power 04, thanks for trying to help me. Luckily I updated the BDM software, and was able to correctly read the memories, then using L.A. wonderful hack the ISN and Vin where changed in the modules. Thanks again for your time.
    I am going to consider this matter closed.
  1. Question 2005 E60 Factory Option Codes
    By Barry325 in forum 2004-2010 (E60,E61)
    Last Post: 06-22-2008, 09:25 AM
  2. How much to pay For Break Pads and Rotors? 2005 - E60
    By amolwankhede in forum 2004-2010 (E60,E61)
    Last Post: 06-17-2008, 06:10 PM
  3. amp for 2005 E60
    By osgoor in forum BMW Parts Wanted
    Last Post: 01-31-2008, 10:04 PM
  4. 2005 e60 530iA for sale in NJ 25K this week only
    By z0lt3c in forum New York / New Jersey / Connecticut
    Last Post: 10-29-2007, 11:59 PM
  5. 2005 e60 530iA for sale in NJ 25K this week only
    By z0lt3c in forum 2004-2010 (E60,E61)
    Last Post: 10-28-2007, 04:03 PM
