Results 1 to 19 of 19
Thread: Front Bumper Removal Airbag Question?
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    1995 525i 5 SPD.
    i am in the process of sanding and priming my car. I have the front bumper almost off but, I see a connector, which I believe is the air bag sensor. Should I disconnect the battery prior to unplugging the connector?
    Thanks in advance!
    Dec 2013
    Chicagoland area
    EXOTICS
    Wait for 10~15min. after battery disconnection before unplugging SRS connections.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I think it's the temperature sensor. I found a topic on this forum and the person had pics and the yellow connector I'm talking about is the temperature sensor.
    Virginia
    95 525, 93 M5, 05 X5 x2
    It's the temp sensor. The connection for airbag deployment is behind the bumper, so nothing else to disconnect. The bumper should slide off after removing four bolts.
    Do me a favor if you can; would you please take a photo of the backside of your bumper after it's off the car and post it here?
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Sure!! Will do in the morning. Too dark now.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by GregT53 View Post
    any specific part of the bumper? Close up pics?
    SC
    E70 | FZJ100 | Z31
    If you're standing in front of the car pulling the bumper out toward you, the temp sensor is to the lower right, just left of the fog lamp.
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    You will have to use a screw driver to move the plastic liners in the wheel wells away from your bumper for it to just slide off. I tend to use my nice big picket knife and a screw driver. Makes it come off nice and easy.
    Andy
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by dgz32 View Post
    thats the connector I was talking about. I saw a thread with pics and it stated it was the temp sensor. I should have searched more before posting.
    Virginia
    Quote Originally Posted by drewusmaximus View Post
    Looking to see if there is a cover on the backside lower portion. Just a pic of the whole bumper, but not too far away. Thanks much!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    no problem! Thank you for the advice!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Let me know if this will suffice.
    http://i1378.photobucket.com/albums/...psqapvz5r3.jpg
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    If you look at the bumper you can see to black plastic pieces on the ends. I believe that is the track that slides on a black plastic item that's bolted on the fender. The piece that's bolted on the fender, mine is broken thus the driver side bumper sags. Does anyone know the name of the part that bolts on to the fender or the part number for that piece? I would like to order it ASAP.
    Thanks in advance!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Here is the part I'm talking about. The part is broken, which is why the bumper doesn't slide into that part and sags. L
    I can't find that part on realoem.
    http://i1378.photobucket.com/albums/...pstdfdb9zl.jpg
    Jan 2017
    Amman, Jordan
    1995 BMW 525i Touring
    The yellow connector is for the temperature sensor.. you can take the whole senor out of it's hole. no need to unplug it. Part# 65811383204
    E34 525i Touring 1995, M52B28 LSD... fully restored.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by zkd View Post
    thats not the part I need. I need the track that bolts on the fender that holds the side of the bumper aligned and in place.
    Thanks for the response!
    Virginia
    Photo is great. Thank you.
    You need these parts for your sagging bumper: 51111944545, 51111944551. You can sometimes pick these up on the auction site, and some of our forum members might have these sitting around.
    Have a look at RealOEM.com. Use the last seven of your VIN and it will pull up your car and all the parts for it.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Thank you very much! I tried real oem but, couldn't find it. A member just contacted me and he has the part.
    Oct 2008
    Kettering,OH
    Boxed up and will go out monday
    Andy
  1. e36 front bumper removal questions
    By twastheglow in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-06-2009, 05:54 PM
  2. Aftermarket Front Bumper Removal
    By Henry80 in forum 1991 - 1999 (E36)
    Last Post: 03-18-2005, 03:35 AM
  3. Front Bumper removal
    By Shardul in forum 1988 - 1996 (E34)
    Last Post: 02-11-2005, 10:45 PM
  4. Front Bumper Removal
    By friggest18 in forum 1991 - 1999 (E36)
    Last Post: 12-29-2004, 12:19 AM
  5. Front bumper removal
    By sgi4side in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-25-2004, 03:45 PM
