Actually, it's still available. $250. M50 OBD I Conversion Package
The parts you need to convert your Motor to an M50 OBD I level. I believe I have them all, but if not, just ask and I can add others. These are removed from a smooth-running creampuff 1994 E36 325i with an 11/93 manufacture date.
Link to a video of the engine running: https://www.youtube.com/edit?o=U&video_id=TulPBae5XtA
Enter chassis code EF45214 on Realoem.com for complete part number details.
The description of the project: https://www.bimmerforums.com/forum/s...what-I-learned
The list of parts I am offering in the package:
OBD1 wiring harness, uncut and unmolested
OBD1 ECU (413 "red label").
OBD1 intake manifold
OBD1 fuel rail, injectors, and fuel line hard pipes for fuel rail
OBD1 engine sensors
OBD1 MAF (intake air flow meter)
OBD1 main engine coolant hose
OBD1 throttle boot, idle control valve, and ICV hose
OBD1 throttle body
OBD1 valve cover and coil packs (optional)
OBD1 support bracket pair and main harness bracket
Pickup available for buyers in the DistMarVa area (inside the beltway). I will be happy to ship it as well, for actual shipping cost, terms FOB McLean, VA. For UPS, estimate about 35lbs from 22101.
Will also consider trades or trade discounts for a Trick Flow Track Heat EFI Ford 5.0 intake, Ford 5.0 MAF/Throttle Body/Injector Package, racing seat, E36 Coupe sunroof delete panel, or MegaSquirt computer.
List Date: 4/28/2017
For more info, click here to view the original listing: M50 OBD I Conversion Package
was the car a 5 speed?
Sent from my 831C using Tapatalk
Yes. 5 speed manual, with VANOS 1. Also no EWS/security to fuss with.
Updated post with shipping cost estimate info.
bump, I kinda forgot about these
Still available, price drop. I can probably do a little better for a man or woman looking to install this on their own car.
Panjo automatically converts the thread header to NLA. Another reason to avoid Panjo.
Thanks for looking.
If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
