Results 1 to 8 of 8
Thread: V8 Swap Header Design
    BALTIMORE
    Hello friends at BFC
    After sitting for a little bit over one year, I've finally started working on my 351W E36 swap again. The current issue I'm running into is headers. I'm incredibly short on both space and motivation. I just can't see how I'll be able to fit a collector for the headers in this engine bay and still make it to the 2-1 merger, even if I shorten the primary stubs on the flanges. Here are a few shots of the space (or lack thereof) I'm working with
    So I had an epiphany while I was in the garage today. Why not make a set of "log" manifolds instead of traditional style headers? The models below are what I've got in mind
    My thought process is that turbo guys have been using log manifolds for decades without major issues. I'm not delusional though, I realize that those guys usually see gains when they switch to tubular style manifolds (the ballpark gains I've seen on the internet seem to range between a 10%-20% improvement) but the "log" style manifolds that I usually see appear to be restrictive in both pipe size and flow. My proposed design shouldn't have sizing issues, though I can easily see how flow could be an issue
    More than anything, I just want to see what other people have to say about this. I really wanna get to driving this car again
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    You will probably see a loss of power with log manifolds, but it may be the only way to make it work. If that's the case, go with it. Turbos work fine with the log manifolds because of the pressure on the opposite side. You could do a set of log manifolds and top them off with a turbo or two. Problem solved.
    Aug 2008
    Houston, Tx.
    '10 X5, '98 M3 - 302
    What about headers like Fendbass did on his coyote swap?
    https://www.bimmerforums.com/forum/s...p-Build-Thread
    BALTIMORE
    Tri-Y headers? Nah, seems like too much effort. Besides, Laminar found an interesting article and posted it in my drifting thread
    http://www.hotrod.com/articles/hppp-...-vs-manifolds/
    Basically, tubular vs stock-log manifolds are about 5% more efficient on an engine with a similar displacement. Granted, I'm sure that the difference would become greater at speeds exceeding 5400RPM (what the guys in that article did for testing) but my max speed will be 6000RPM
    According to the internet, most guys with my setup are making about 320hp wheel with about 350ft/lbs of torque. A 5% reduction is more than acceptable to me
    LS,
    Apollo Beach, Fl
    '92 BMW 735i(W/383 GM)
    Building headers is a bit**. If you build your own, and the car goes down the road, declare victory and have a beer. Very few people do it, and those that have, will salute you.
    Minneapolis,MN
    2003 M5, 2014 535i
    Plenty of factory cars out there with log style exhaust manifolds on N/A engine. Below is an example which is not too far from what you have. Only change I would make to your design is remove that short extension on the opposite side of the outlet.
    http://s254.photobucket.com/user/jfg..._1960.jpg.html
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
    Aug 2008
    Houston, Tx.
    My drivers side is a tri-y. Clears the steering shaft and doesn't hit the abs once I moved it over a bit. Getting out though is a problem because I have to tilt the engine.
    Jun 2010
    Pittsburgh, PA
    5.0 325is
    I have a set of Patriot headers (https://www.summitracing.com/parts/p...view/make/ford). I just HAD to have headers and 2.5" exhaust all the way back. I haven't run the car with them in yet.
  1. E36 FEELER e36 v8 swap headers. sbc 350
    By Bowze in forum Race Cars & Track Parts
    Last Post: 10-07-2013, 05:53 PM
  2. might buy a cheap e28 528e...V8 swap possible?
    By indicaM3 in forum 1982 - 1988 (E28)
    Last Post: 11-14-2006, 08:58 PM
  3. Swapping headers- Any suggestions to help make this easier?
    By Bengali86 in forum 1991 - 1999 (E36)
    Last Post: 02-07-2005, 02:14 PM
  4. V8 swap
    By 93bimmer in forum 1983 - 1991 (E30)
    Last Post: 11-18-2004, 07:32 PM
  5. Need info on V8 swaps into a bmw
    By 1995LT1 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-18-2003, 01:11 PM
