About to order a front suspension kit for my 318is...Researching vendors and was wondering if anyone has any experience with Deutsche products on ebay? Thanks for any info
run like hell. only buy decent brand names from trusted sources.
this is a decent kit
https://www.fcpeuro.com/products/bmw...e30-e30fcakitl
Yes. Name brands only. Too many Chinese replica suspension kits out there with no QC. I'll never forget the thread of the Australian guy's e30 his son wrecked when the tie rods just pulled apart. He bought the $130 full front end suspension no name kit. Your life isn't worth a few hundred bucks. Or maybe it is, but still don't do it, you're putting other people at danger.
When I'm having fun, I need to trust the car. I can't be second guessing whether or not my front end will just decide to split and go opposite directions.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
