BMW of Bloomfield
Results 1 to 13 of 13
Thread: 96 BMW M3 with S54 swap, Hellrot/Black - No Longer Available
    Jun 2002
    Burlington, Wa
    96 M3
    I am selling my Hellrot on black 96 M3 with a working S54 swap. I have owned for the last 7 years, been a great car but it is time for me to move on. The swap runs excellent, no engine error codes (needs ABS swap finished up and SRS reset), tons of maintenance on the motor, and lots of work to the rest of the car (records for the last 7 years). Swap was completed about a year ago, car has just over 5k miles on it with the swap. Interior is in excellent shape, exterior is solid for a 20 year old car with 245k miles (RF bumper corner scuffed up, a few little dings & rock chips). Asking $13.5k for it, PM or call/text at 36o-77o-9o86.
    S54 mods/maint
    107k miles on the motor
    New water pump, thermostat
    New rod bearings
    Valve adjustment at 102k
    S54 Z3M radiator
    E46 S54 oil cooler
    K&N Intake & heat shield
    Used US headers & section 1, rear is part e46 section 2 and factory e36 M3 muffler
    Transmission
    UUC LTW flywheel with M5 sprung clutch
    New fluid, Redline ATF (shifts great)
    Custom SSK
    Suspension
    Koni yellows
    Eibach sport springs
    SPC rear adjustable camber arms
    Bushings & BW spacers for rear control arms
    Front control arms & Powerflex poly rear bushings
    Rear subframe Powerflex poly bushings (NIB, not installed)
    BW wheel studs (bull nosed)
    Front brakes have brass guide pins
    BW SS braided brake lines
    TRM MT1 17x9 wheels
    245/40-17 BFG G-Force Comp 2 tires
    Interior
    Black leather manual vaders with no rips/tears/holes, heated but not hooked up
    ZHP shift knob
    Kenwood KDC-X695 headunit
    Infinity speakers
    Planet Audio 600w 5 channel amp
    Alpine 10? sub
    Exterior
    Custom bi-xenon HID headlights
    Smoked side markers
    List Date: 4/26/2017
    For more info, click here to view the original listing: 96 BMW M3 with S54 swap, Hellrot/Black
    This item is no longer available.
    Apr 2016
    Miami, FL
    1997 E36 M3 Coupe
    Ive always wondered what a black interior swap on modena would look like, not bad.. did you swap it? Car looks very solid GLWS
    Feb 2016
    Rogers AR
    1995 BMW M3
    very nice! is the ac working or has it been deleted?
    Sent from my 831C using Tapatalk
    Jun 2002
    Burlington, Wa
    96 M3
    Never installed. Sounds like it isn't that hard to add if you live somewhere that needs it. I still have about all the parts.
    Jul 2004
    Las Vegas, NV
    '99 Dakar M3 '09 SpGy M5
    Jun 2002
    Burlington, Wa
    96 M3
    It should pass smog, still has the factory cats and o2 sensors. Uses the OBD plug and talks to the engine just like if it were in an e46.
    joenationwide's Avatar
    joenationwide is offline Makes Cars Dance BMW E36 M3 Expert
    Leesburg, Virginia
    95 M3 (GTS2), 99 M3
    Thank god this is in the PNW and I am in the Mid Atlantic otherwise I'd have to buy this thing! GLWS!
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    NIce price - you're Getting a lot of product and man hours for a low cost. I'd be in the upper teens if I were you.
    Sep 2014
    Woodbury, MN
    11 M3/05 ZHP/100 Series
    Is this car still available?
    -Chris
    CURRENT - 2007 GT3 in GT Silver - 2003 330i ZHP in Silver Gray - 2011 M3 Sedan
    6MT Only
    Jun 2002
    Burlington, Wa
    96 M3
    Still available. Pitt, you should buy it and have a killer drive back across the country with it!
    May 2009
    Pittsburgh, PA
    I wish man, a coupe would be a nice addition. Anyone looking, check out engine conversion forum and you can see the work that goes into the swap. This is a great deal.
    Jul 2004
    TC
    '98 M3
    Who did the wiring and what tune are you running? Is this a full dbw setup? Did you change the cluster?
    Thanks.
    Jun 2002
    Burlington, Wa
    96 M3
    I did the wiring and running a factory tune. Factory dbw setup so drives like stock. No cluster changes as it all works fine, only the mpg gauge doesn't work.
  1. Replies: 10
    Last Post: 06-08-2016, 01:26 PM
  2. Need some help finding an old theread... blue e36 m3 with s54 swap FS
    By m3j0n in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-10-2015, 01:55 AM
  3. Replies: 47
    Last Post: 11-06-2014, 01:50 PM
  4. E36 1998 BMW M3 with LS3 Swap for Sale
    By Kaane in forum 3 series & Z Series
    Last Post: 12-03-2012, 02:33 PM
  5. FS: 1995 M3 with S54 Swap
    By Johnbennett103 in forum 3 series & Z Series
    Last Post: 12-19-2011, 10:03 PM
