Results 1 to 10 of 10
Thread: 3.15 rear diff swap woes
    Dec 2014
    2002 Bmw 330ci
    I read a couple of articles and was under assumption that this swap would be direct bolt on. I have a 1997 540/6, and installed the 3.15 rear diff from a 2001 automatic 540 however the rear axles are different. Bigger than what I have, now I have a question if I get automatic 540 axles will they fit my 1997 hubs? any help is appreciated
    current: 2002 BMW 330ci
    past : 1997 540/6 Euro delivery, 1979 Bmw 733i euro 4spd, 1983 VW Gti, 1993 mitsu mirage, 1987 mitsu starion, 1986 mercedes cosworth, 1991 audi 200 20v wagon and a bunch of saab 900's, bmw e-30's and vw convertibles
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Quote Originally Posted by euro23 View Post
    They will fit.
    The nut on the wheel hub is a killer though.
    Absinthe makes the tart grow fonder
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Yep.
    The 540 autos, which got the short diff, also got fatter axles somewhere inbetween the standard axles and the M5 axles (or "halfshalfs" as they are often called in USA)
    While the fatter axles might be appealing, your easy route is to just swap the flanges off your old diff. Would put you back in business in almost no time. As Stranger says, swapping axles is a whole extra project to take on, a bit more work than one would hope/expect.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Dec 2014
    2002 Bmw 330ci
    ahh ok thanks for the info, yes those don't look fun luckily my car is pretty rust free
    Mar 2010
    Yeah. It's not like the stock 540's are known whatsoever for blowing axles - they seem to be more than adequate... of course 'upgrades' are always evilly tempting to car dudes but chances of destroying an axle because it's not stout enough are extremely low on a standard car.
    2003 M3CicM6 TiAg
    Former:
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Yep.
    His old 97 flanges (I'm 99% sure) won't lock into the M5 LSD. The locking rings on the spline stubs are in a different location.
    I can post some pics of them if needed.
    Pretty sure I have a set of M5 flanges kicking around here if you want some measurements off them.
    Getting the castle nut off the end of the half shaft is a piece of cake compared to getting the splined end of the half shaft out of the bearing assy.
    Mar 2014
    San Diego, CA
    09 Rx8 R3
    Yeah that is true for the M5 diff.. but he's using an auto 540 diff. Which should work.
    Mar 2010
    Yep, he's not an M5 swap Jim.
    2003 M3CicM6 TiAg
    Former:
    Feb 2014
    E39 535i
    The flanges will just pop out pretty easily with the help of a pry bar, and a short sharp tap with a dead blow hammer pops them back into place
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by speed7 View Post
    Oops, missed that important part...
  1. FS: 3.15 rear diff, local, - pick up only
    By atakm in forum New York / New Jersey / Connecticut
    Last Post: 01-28-2007, 08:14 PM
  2. Rear Diff Swap Problems
    By djfmf in forum 1992 - 1999 M3 (E36)
    Last Post: 11-07-2005, 03:32 PM
  3. 325 Manual Trans - Rear diff swap
    By jamesclay in forum 1999 - 2006 (E46)
    Last Post: 01-11-2005, 01:07 PM
  4. Rear diff swap question ???
    By Fastfred92 in forum 1991 - 1999 (E36)
    Last Post: 10-14-2004, 01:39 PM
  5. FS>3.15 Rear Diff
    By DMK in forum BMW Parts For Sale
    Last Post: 12-04-2003, 01:00 PM
