I have a high cluster on my new-to-me 530i. Typical missing pixels make the OBD LCD unreadable...
I've watched many videos, and have read many threads so I'd like to clarify a few things with you guys.
- What is the best kit to buy? Solo ribbon cable vs. ribbon cable w/ LCD?
- I'd like to avoid drilling. What are the tools needed to safely remove the cluster needles?
- What else should I replace while I have the cluster out / open?
Let me know what you guys think.
Talk to Paul (blacknight and I don't remember the numbers part of his name) in the E38 forum. He's the resident pixel guy....He may even follow this forum as well.
2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
2003 M3 - 210K - BMW Euro Cross Drilled Rotors
Thanks, it's blackknight530i btw .
My main thing is offering to do premium upgrades for clusters. It's ideal for people that plan to keep their car for a long time and don't want to deal with pixel failures again. The older clusters with the glued on ribbon cables had a flawed design that BMW finally fixed starting in late 2003 by using a connector on the circuit board instead of gluing the ribbon. I am able to mileage correct and code these to be plug and play to your car and they won't have pixels fail again. The older designs, even when repaired would eventually fail again after many heat cycles.
I don't do what I call a basic repair anymore as it just isn't worth it for me. If you only plan to keep the car for a year or two, I recommend some of the other shops to do it, but if you want to keep it for years, send me a message.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Worst part is, I figured i figured it out 5 secs after I hit post, your build thread was like 4 topics down from this one at the time "facepalm* haha
