Results 1 to 6 of 6
Thread: can strut mount bearings be replaced alone?
    Sep 2014
    New York And CT
    07 Tundra, 02 530 14 x5
    Fling to be replacing my front shocks soon. And wanted opinions on the strut mount bearings. Can they be replaced alone?
    https://www.ecstuning.com/b-genuine-...g/31331090612/
    also so debating on either Meyle struts or Sachs. Sachs about $100 ea. And Meyle $60 ea. Any opinions on Meyle.
    2002 525i
    San Jose, CA
    1997 BMW 540i 6 speed
    The strut bearings are cheap enough to replace, although they don't wear much.
    I once installed a Meyle tie rod that lasted only 20k miles. When I decided to replace it, I found the BMW puller would not fit on the idler arm joint.
    I ended up having to remove the idler arm still connected to the tie rod, and filing the tie rod side of the joint so that the puller would fit.
    I vote no on Meyle parts as a result. A $40 difference is not worth it.
    Sep 2014
    New York And CT
    My bearings feel rough when I spin them. So is it replaceable (easy and simple) with the $12 part or do I need the entire strut mount. I was leaning more towards Sachs myself
    2002 525i
    Sep 2014
    New York And CT
    No one can answer this...
    2002 525i
    May 2016
    NYC
    2003 BMW 530i
    if i'm not mistaken these are only on the i6 cars with EDC and V8's right? RealOEM diagram of my 2003 530i without EDC does not show this part for the non-edc setup
    http://www.realoem.com/bmw/enUS/show...diagId=31_0256
    Sep 2014
    New York And CT
    I wasn't sure. That was why I was asking. I don't believe I have edc. So this wouldn't work for me anyway?? Is that what you're saying?
    2002 525i
  1. Replies: 16
    Last Post: 06-03-2013, 10:51 PM
  2. Replies: 4
    Last Post: 02-08-2011, 12:14 PM
  3. how much play should be in the upper strut mount bearing?
    By lovemyiX in forum 1983 - 1991 (E30)
    Last Post: 02-02-2011, 09:03 AM
  4. Those who have replaced Strut Mount Bearings
    By sbkrider in forum 1991 - 1999 (E36)
    Last Post: 04-30-2007, 07:33 PM
  5. Can Our Rear Window Be Replaced?
    By ADAM///M in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-28-2003, 10:07 PM
