Results 1 to 9 of 9
Thread: Would it be easier to replace power steering lines with the motor raised?
    Oct 2015
    Washington, IL
    2003 540i6
    I plan on replacing my motor mounts soon, but I also need to replace the power steering lines that go to the box. I've been putting off the power steering lines because my rtv patch has been holding up and I'm dreading the tight work space above the steering box. So I'm thinking I'll lift the motor, replace the power steering lines, then replace the mounts. Would lifting the motor give me that much more clearance to replace the lines, or is this a silly idea? It's the M62 (for the mobile users)
    2003 540i/6
    Jan 2016
    Ca
    2001 525it
    Certainly you would think it would give you more space
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    You need to raise the motor to replace the mounts so do the PS line at the same time.
    Got a crows foot? That would help on the top banjo bolt.
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    I did this job when installing my m5 box, lift the motor till the fan touches the shroud, no special tools needed, the hardest part is keeping the crush washer on the banjo bolt while trying to get it started in the hole, do not force the bolt, thread in by finger only
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    JimLev's Avatar
    Sundance Mesa, NM
    Put some grease on the banjo bolt to keep the washer in place.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    +1 on the tip of using some grease to hold the banjo bolt washer. It will take longer to get the washer in place under the banjo hose end. Two sets of hands help the most. Motor up or motor lifted the second trick is to have 3/8 " drive extensions with lots of swivel joints to hit the bolt. I taped the bolt to the socket to begin and then pull it loose to torque down as the last thing you need down there is a piece of tape under the bolt when you think your finished.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Apr 2003
    Back in Hunt Valley, MD
    96 ACS S3 CLS, 02 540iA
    Quote Originally Posted by 1999 540i m View Post
    This. Definitely second that. Thread that sucker in by hand...can be a bit of a pain to do while keeping the crush washer in place, but you do NOT want to cross-thread that thing. Grease to keep the washer from dropping out is also a good tip.
    But yea...definitely need to raise the engine a bit to gain better access of the P/S hoses going to the steering box, so might as well do them at the same time you do the engine mounts...
    Alvin Caragay
    Mpire Automotive (https://www.facebook.com/MpireAutomotive/)
    '96 AC Schnitzer S3 Sport CLS Replica (https://www.facebook.com/ACSS3SportCLSR)
    '02 E39 540iAT
    Apr 2015
    United States
    1974 estoril blue 2002
    Damn, thats genius! I had that bottom crush washer slip out several times on reassembly after I replaced rod bearings. Never again will that happen...
    Sent from my SM-G930P using Tapatalk
    Oct 2015
    Washington, IL
    2003 540i6
    Thanks for the info. -Turns out I only had one of the lines, so I had to order the other one today. I'll report my success when the job is finished.
    2003 540i/6
  1. Would It Be Illegal To Remove The Sunroof From An E36 M3 For SM or BSP If......
    By jmciver in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-27-2009, 02:57 AM
  2. Would it be horrible to put SO3 on Front of E46 M3
    By Bham BMW M3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-09-2003, 01:37 PM
  3. Replies: 2
    Last Post: 09-08-2003, 05:06 PM
  4. Would it be possible to make a titanium racing wheel?
    By crazn in forum 1992 - 1999 M3 (E36)
    Last Post: 04-23-2003, 07:46 PM
  5. Would it be hard to put 9006 bulbs in the H1 slot?
    By Joey325i in forum 1991 - 1999 (E36)
    Last Post: 02-28-2001, 10:06 AM
