Results 1 to 3 of 3
Thread: E36 328i idle questions
    Jan 2016
    Troy, MO
    BMW 328i
    So I've fixed a lot of my engines issues and it passed safety however recently at idle when I'm at a stop light or w.e. Sometimes my car will surge and hit 500 rpm and do this a few times in a row before stopping it is an automatic but this doesn't affect drivability it still picks up and goes like crazy just want to get all my gremlins out does anyone know any. Fixes my check engine does not come on and there are no pending codes either
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Check for vacuum leaks, cracked intake elbow, PCV hoses, ICV hoses, Intake gaskets, Injector o rings. Also try cleaning the ICV, if it is gummed up it won't respond properly and will overshoot the idle RPM. It should freely spin and "clack" when you rotate the ICV back and forth in your hand. I have had some so dirty it was hard to move the vane.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Jan 2015
    AZ
    96 328i, 92 318i
    Quote Originally Posted by jc43089 View Post
    This p much sums up all idle issue related stuff lol. If it doesn't affect drivability I'd first suspect a vacuum leak. Spray some carb cleaner around your intake and see if the idle fluctuates.
  1. e36 328i Sedan questions
    By zgoodgall in forum 1991 - 1999 (E36)
    Last Post: 02-04-2012, 03:08 PM
  2. E36 E36 328i Selling, questions/advice needed (Australia)
    By cakemaphoneige in forum 3 series & Z Series
    Last Post: 05-23-2011, 08:36 AM
  3. e36/m50 idle question
    By vidgam in forum 1991 - 1999 (E36)
    Last Post: 05-02-2011, 03:28 PM
  4. 1998 e36 328I RIMS QUESTION!!!
    By IhaveanE36 in forum 1991 - 1999 (E36)
    Last Post: 06-18-2009, 09:29 PM
  5. RIP e36 328i & some questions....
    By Don Veneziano in forum Middle Atlantic - US
    Last Post: 06-02-2009, 12:19 PM
