Results 1 to 5 of 5
Thread: 5 speed swap in my 81 320i
    Mar 2017
    AL-GA
    1981 bmw 320i
    I recently pulled a 5 speed from a 81 320i.
    I have been reading the various 5 speed swap threads but i didn't see much on the flywheel.
    The only place is see the oe style for sale is at Bavarian Autosport PART#: (11 22 1 270 292) $250
    I didn't get the original flywheel out of the car as i ran out of time.
    Can you refinish the face of these flywheels or just buy new?
    Also i need to go back and get the driveshaft and rear diff.
    The 5 speeds gear ratios probably wouldn't like the auto diff ratio?
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    You can refinish it once for sure. I live dangerously and just deglazed mine. No issues, but I wouldn't do it on someone else's car
    -John
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Emory cloth over the whole surface works well, I have done this before a few times and you cant tell difference between cut by lathe or sanded with emory cloth, your cleaning the surface to get the clutch to bite on the flywheel. The first time I asked around about this all the shops were in a panic as they wanted the money to cut the flywheel down, ran for the life of the clutch no issues.
    Wipe clean the surface face with acetone(glove,mask, ect) or similar to clean the debris and remove oil,grease, dirt and so forth.
    Randy
    Nov 2007
    Cool
    Also while there , a new rear engine oil seal can be considered its behind the flywheel.
    Randy
    Dec 2008
    Canada
    '82 320i, '86 Jetta,
    Quote Originally Posted by osburn383 View Post
    Smeh, still would be quicker overall than with the auto, and great for road trips while banging out the fuel economy.
  1. 4 speed to 5 speed swap in my 77 320i
    By bmac320i in forum 1975 - 1983 (E21)
    Last Post: 09-18-2013, 10:35 PM
  2. Starting a 6 Speed Swap in my 1994 M60 740i
    By southernk30 in forum 1988 - 1994 (E32)
    Last Post: 10-19-2012, 11:39 PM
  3. Questions about 6-speed swap in 540i
    By JV1021 in forum 1988 - 1996 (E34)
    Last Post: 10-12-2006, 02:42 PM
  4. question about my 81 320i
    By 320Idriver in forum 1975 - 1983 (E21)
    Last Post: 09-12-2005, 01:39 PM
  5. Six Speed Swap in 540i
    By Sideburns in forum 1988 - 1996 (E34)
    Last Post: 09-05-2005, 10:58 AM
