88 735i manual. Have alot of shake and shimmy. Replaced upper & lower arms which helped alot but Eurofed in Atl (well respected shop) said the steering box is worn out. 20 degree of play left & right and cant be adjusted anymore. When i wobble the steering wheel L&R it also "clunks" and wanders on the road quite a bit when driving. Shop foreman said all steering and suspension components are tight and the box is the issue. Never heard of a steering box causing shaking/shimmy or clunking noises. Its always been control arms and stabilzer links in my experience. Thoughts? Anybody go a good used box. Reman box is $292 on ebay. Not bad. Thanks guys.
Often the steering links can be the problem http://www.bmwe34.net/E34main/Mainte...ering_link.htm
Front end noises by Bruno:
A lot of parts in the E32 can produce "clunk", "clink" and other "clank" noises. The trick is to check the cheapest parts first.
Check list from the more probable to the less.
Loose strut housing nut
If you changed your shocks, you may have a loose strut nut. Take a monkey wrench a tighten it. You don't need to remove the shock assembly, just jack up the side.
Sway bar links
Place you car on ramps or stands then shake the link and check for "clink" noise and play. You can also remove it and drive slowly over bump to see if the noise is still here.
Steering links
Shake the link for play. Check the ball joint.
How to check ball joints for play and noises:
Did you check for play with the car on the jack stands? If yes, the joints may be still bad. You need to check with a large channel lock type pliers and the car at ride height, on ramps for example. If you can squeeze the joints top-to-bottom when they are in their normal position, they are finished. Time to replace the arm or ball joint.
Thrust arms (upper control arms)
Cause the infamous shimmy (50-60 Mph) and severely enhanced brake shimmy. If the bushings had not been tighten under load, they will be damaged. Check the bushings for cracks, jack up the front with the wheel on and shake the wheel to locate the noise.
Use a pray bar under the arm to check ball joint play (they "clunk" when worn).
Control arms (lower control arms)
Check the bushings for cracks, jack up the front with the wheel on and shake the wheel to locate the noise. If the bushings had not been tighten under load, they will be damaged. Use a pray bar under the arm to check ball joint play (they "clunk" when worn).
Strut bearings / shock mounts
BMW mechanics say that the front ones last for a long time. Lift the front of the car, shake the shock absorber for play.
Steering box mounting bolts
I had a vicious clunk in my front end during slow turns, mostly backing in and out of parking spaces. I tightened the large gland nut at the top of the strut insert, and replaced the sway bar links, but it made no difference. Finally I took it back to the guys who did the shocks and thrust arm bushings. They tightened the steering box mounting bolts, and the bolts that hold on the front subframe and it totally fixed the problem. (Information from J. Calhoun)
You can easily locate noises by placing a screw driver with the handle against your ear and the tip against the part to be checked.
If any of the ball joint boots are damaged, it is just a mater of time before the ball joint goes bad, change the part.
self steering from the rear are the beer cans http://www.bmwe34.net/E34main/Mainte...ameBushing.htm
