I seem to remember reading a post recently about loose injectors, but I could not find the post...
Shot a video showing how loose my injectors are- I would appreciate any insights.
Thanks in advance!
Eric
The video is private. Ever replaced the bushings? Any symptoms of a vacuum leak?
-John
John-
Thank you for the reply. Video is now viewable.
I have not replaced the bushings.
At low idle, it is sometimes a bit choppy, but that would be the only symptom to speak of.
It's normal for them to wiggle like that. It is actually better than if they don't, as it means the rubber seal is still soft. As the seal ages it will harden and crack.
Thank you audioscience10. No problem finding something else that will need my attention!
