Page 1 of 5 12345 LastLast
Results 1 to 25 of 101
Thread: ABS intermittent
    Aug 2012
    Central, MD
    1995 M3
    ABS intermittent
    1995 E36 M3.
    Symptom:
    Start car, all is ok.
    Brake hard and engage ABS, ABS light comes on, and ABS seems to disable.
    The rest of the session is without ABS.
    Turn car off, restart car, all is ok.
    FYI, I haven't had the time to check sensors yet. But just wondering, are the above symptoms typical of a bad sensor, bad ABS computer, other?
    Jan 2002
    North Augusta SC
    Same here, except mine comes on without braking on warmup lap first session. Doesn't come back for the rest of the weekend. Lots of folks say it is the pedal travel sensor on the front of the booster unit, but I haven't tried replacing it yet.
    '95 M3 S54 Track Toy
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    Aug 2012
    Central, MD
    1995 M3
    FYI found this. Looks like a pretty extensive debug guideline, and specifically for the E36 chassis.
    https://blog.bavauto.com/14248/bmw-d...es-and-others/
    Apr 2014
    Slidell, LA
    Many
    I used that procedure to diagnose my issue. For me, it was a cut sensor wire - different symptoms from you.
    Jul 2012
    Orlando, FL, USA
    1993 BMW 325i
    I've had the same issues before. Once it was the ground under the dash on the passenger side. Another time it was a front abs sensor pin in the connector that snapped when I plugged it in.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by Zxc4 View Post
    In your case, the ABS light came on only after braking hard enough to kick in the ABS, and went away after restart?
    Completely disconnecting an ABS sensor causes the ABS warning light to stay on at start. So I don't think I have a complete open on an ABS sensor line.
    Jul 2012
    Orlando, FL, USA
    1993 BMW 325i
    That's correct, exact same symptoms. I went overboard though trying to diagnose and resoldered the pedal travel sensor and the entire abs unit when I was trying to diagnose. Check the easy stuff first like grounds and do some simple multi meter tests
    Aug 2012
    Central, MD
    1995 M3
    Interesting. Thanks. A loose ground kinda makes sense though. Could get shaken loose by violent braking.
    Charlotte
    2012 GTI
    I had a similar issue, though sometimes the ABS light would come on before any hard braking. I replaced all 4 ABS sensors and that didn't fix it. Turned out to be the pedal travel sensor.
    Aug 2012
    Central, MD
    1995 M3
    Thanks, will check that next.
    Boston, MA, USA
    '99 M Coupe
    I'd read the OEM code or have it done. The ABS unit has detailed chassis-specific codes. I saved a lot of doing doing that (bad wheel sensor in my case).
    Dan Chadwick
    Boston Chapter BMW CCA Instructor Development.
    Near-Orbital Space Monkeys, E30 M50-ish
    Driving Evals on-line evaluations for Driving Schools. Paper forms are just wrong.
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Quote Originally Posted by Evergreen Dan View Post
    This. For the love of all things holy....
    I have been chasing abs issues for 5 years, don't throw parts art it until it has been properly diagnosed IMO....
    Aug 2012
    Central, MD
    1995 M3
    So, it's a 95, obdi.
    Do the ABS faults show up via the pedal stomp test?
    Spanish Springs NV
    17 Sprinter, 94 325is
    Quote Originally Posted by aeronaut View Post
    No they do not. You need a scanner.
    Cleveland
    135i, e36, A4 Avant
    If you have the stomach for it, and and old computer with a serial port, get INPA and the tinyADS adapter. Then you can get the codes from the ABS unit.
    Chris
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by bjh102 View Post
    Ug...YAS (Yet Another Scanner).
    I have a friend....
    Mar 2004
    Fort Worth TX
    Wreck Miata,Dirty Thirty
    Likely a torn solenoid ribbon wire inside the ABS pump, re-wire it. But of course, do you homework and check the easy/obvious things first.
    Springfield, IL
    Quote Originally Posted by Greg S View Post
    I rewired mine and that didn't work, then swapped a new/used pump in and that didn't work, then had codes read and they found a wiring issue, then fixed that and now I think the pump I swapped in needs rewired. Crap.
    Aug 2012
    Central, MD
    1995 M3
    Well crap, my friend, all around good mechanic, and more importantly european car shop owner, hooked up his brand new 'spensive SnapOn diagnostics tool, and said it 'couldn't communicate with the computer'.
    I'm guessing a BMW shop would be quite costly to read these codes.
    Is there any reasonably priced scanner that can do this?
    Springfield, IL
    Should be under a hundred bucks at a local independent BMW mechanic.
    Jan 2006
    Mechanicsburg, PA
    yes
    EasyDis/GT1...find someone in your area with a laptop setup via the forums. Best investment I ever made...for BMWs. Typically, for 95M3's I find the brake switch distance sensor is the problem.
    Don
    Aug 2012
    Central, MD
    1995 M3
    I was quoted $120 and $150 from local BMW shops. Ug. Ima do some basic resistance diags this week before spitting out that much.
    Odd I can't get this to occur anywhere except track.
    Not a huge deal, more than not having ABS on track, it's the surprise of not having ABS at some random hard braking point.
    2 track days coming up this weekend!
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Agreed. If you can't get the issue solved before this weekend, I'd highly suggest temporarily disabling the ABS. At least then you can predictably flatspot your tires! Good luck!
    Jan 2002
    North Augusta SC
    I've been tracking my M3 regularly since 1999. I've had two "off-course excursions" out of about 200 days on track. Neither would have happened if my ABS had been turned off. Hard to say if there were occasions that ABS might have prevented an issue.
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by OCRentAPopo View Post
    Exactly!! It'll temper my trail braking, but maybe it'll make me pay more attention.
    Quote Originally Posted by m3bs View Post
    Do explain.
  1. ASC/ABS intermittent error
    By legoman67 in forum 8 Series (E31)
    Last Post: 04-18-2013, 01:39 AM
  2. Abs Intermittent
    By ronnie38 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-16-2007, 02:52 AM
  3. ABS intermittent probs... the relay?
    By luckytopher in forum 1991 - 1999 (E36)
    Last Post: 09-18-2005, 10:59 PM
  4. abs and asc lights on intermittently
    By dmw in forum 1992 - 1999 M3 (E36)
    Last Post: 12-19-2003, 02:04 PM
  5. ABS light intermittent
    By grimfandango in forum 1991 - 1999 (E36)
    Last Post: 05-27-2003, 12:28 AM
