Hi all, I recently bought a 1987 BMW 325i and it has developed an issue where it gets up to temp at a steady rate yet keeps getting hotter at the same pace. I noticed coolant leaking from the radiator so I replaced the radiator and it made no difference. So I replaced the thermostat and still no difference. I'm only 16 and have only done basic repairs in my American cars, so I don't really have any mechanical knowledge especially with BMW. I can't see anything that would be causing the issue. I read that if the fan that's behind the radiator wiggles it means the water pump is bad but mine is pretty tight, but who knows if that's true. Also the cars starter just broke, but I don't think there is any correlation. Any advice is appreciated!
Mike
check under the oil cap on the valve cover. you are checking for a milky or foamy residue. would kinda be the color of cappuccino. also check the oil dipstick for any evidence of coolant. i suspect the head gasket has blown. this in tandem with other cooling system issues likely is why the car got parked in the first place. best time to check is after the car has run for a short period with a warm engine.
^ Blowing the headgasket within 16k miles sounds like a challenge, but who knows indeed.
OP, does it overheat while driving, or only when standing still?
When you mentioned that it overheated while moving it around on the driveway it sounded to me that your fan clutch is shot.
This would mean that your fan is spinning, but not as fast as it should to create enough drag through your radiator to cool down the radiator.
If it also overheats while going 30+ miles an hour this will not be your (only) issue though.
Is it actually overheating? Are you going by the gauge or are there other signs and where does the needle sit when it is completely cold. Once it gets past operating temperature is the upper radiator hose getting hot? A IR temperature gun would help to take some readings.
Remember, there was nothing in the cooling system when you first got the car. For $100 you can get a timing belt kit and a water pump plus the cover gasket and new coolant to fill in. Give it a good flushing, it could have corrosion/rust since it sat dry for so long.
i sure wish I could buy the car from you, I would come and get it right away....
I believe once you replace the water pump it should run fine. When replacing the pump be sure to clean the cavity real well and make sure the block cooling ports are clean as well.
Do a radiator flush with cleaner. Leave cleaner and water and drive it for a day. Flush system again. Use Bmw coolant mix with distilled water...Make sure you bleed the system propery thereafter. Also, change thermostat. If that does not do it, you might have a bad waterpump and blow head gasket.
if it overheats while driving its not the fan. (unless you have more than one issue).
you need to verify it IS over heating. as the temp goes up, does the electric fan come on. if not, that may and indication that its just the temp sending unit.
air in the cooling system.
if you have a bad fan clutch you will be able to easily stop the fan while the engine is idling.
spin the fan with it cold then compare it when hot.
[__] RUNNING: [__] NOT RUNNING: 86 PORSCHE 930
[__] RUNNING: [__] NOT RUNNING: 88 BMW 325is 200K+
[__] RUNNING: [__] NOT RUNNING: 2000 MERCEDES E320 WAGON
[__] RUNNING: [__] NOT RUNNING:99 GRAND CHEROKEE 160K::
[_:_] RUNNING: [__] NOT RUNNING: mazda B2200
I didn't explain the issue correctly, when sitting at idle it over heats but stops before reaching the red part of the temp gauge. When I rev the engine a few times the temp gauge flies back to the middle then overheats again after 3 or 4 minutes. Not sure what it does when driving as I have not registered the car yet so I can't really drive it for a long period of time
Sounds like a weak fan clutch and/or air in the cooling system based on your most recent post.
overheats because it is a 30 year old car
Those fan blades are plastic - be sure to just do the one sheet of newspaper and with the engine at low idle, as shown in that video. If it's the original fan, brittle plastic and maybe a hairline crack or two could lead the "newspaper test" damage a blade.
On my recent timing belt & water pump change, we found the fan had one blade missing a chunk and a couple others cracked.
I also had trouble with "overheating" where temp gauge would keep rising; driving in the rain, once up to temp it would bounce around a bit. Turned out to be a loose ground wire on the cluster panel. Tightened up and now seems ok.
Read coolant temps with heat gun, upper and lower hoses
"So I believe the fan clutch is screwed."
Love the way that video ends. Hilarious.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
