Results 1 to 3 of 3
Thread: M52 loss of power fixed ! Crank sensor and 02 sensors
    Apr 2017
    Newcastle upon tyne
    1998 328i coupe
    Hi, I'm just writing as a bit of advice for anyone who has suffered loss of power in their M5x engine in the e36 or e39 . Symptoms were loss of power when warm and power surges on wide open throttle, between 2000-4500 rpm. When cold it ran fine and pulled hard .
    I changed the crank sensor and it made a little difference, but not 100% . I then bit the bullet and fitted 2 new NTK o2 sensors and that fixed the issue, runs fine hot or cold. I knew it was a sensor which controlled fuelling because cold it runs on a base map and ignores sensor input. The car has 220,000 miles on it and the lambda sensors were the originals ! Well worth changing its transformed the car, much stronger mid-range.
    Nov 2016
    texas
    1998 328is
    did you have a check engine for any sensors? i changed my 02 sensors but it still hesitates at 3.5k and whenever its cold it will rev up fine but when warm i will rev it up, the rpm needle will fall more slowly and stop at 1k revs then fall down to normal idle.
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
    Dec 2013
    Chicagoland area
    EXOTICS
    A diagnostic scan with a BMW specific scan tool/software, may provide an answer or clue.
  1. E39 Loss of power at certain rpm and speeds.
    By DullestStimpy in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-08-2015, 12:29 PM
  2. loss of power , wacky gas gauge , and bogging bad MPG
    By Tanner325ixx in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-17-2014, 08:17 PM
  3. help!!! loss of power with ASC EML and battery lights on
    By mahmoudoski in forum 1996 - 2003 (E39)
    Last Post: 02-16-2014, 10:58 AM
  4. m62 flat line(loss of power) at 4k rpm and regains at 5k rpm
    By Johnny Kim in forum 1996 - 2003 (E39)
    Last Post: 10-04-2012, 08:00 AM
  5. S52 occasional hesitation and loss of power - crank sensor? VANOS?
    By ClayMan in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2009, 10:12 PM
