Results 1 to 4 of 4
Thread: 01 3.0 versus 03 3.0 differences are they interchangeable need to do a swap
    KNOXVILLE
    2001 740il
    Ive got to do a swap on my 03 3.0 z4. I found one locally thats in a 01 330 is this doable without doing major changes? There both dual vanos engine but something changed around 9/02 from what Ive seen just not sure what it is?
    Any help be appreciated
    Jul 2004
    Houston, TX
    36 Cylinders
    You have MS45 ecu, the 330i in question has MS43 ecu, so some sensors will be different. You will have to use all your sensors to go with the MS45 ecu.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    KNOXVILLE
    2001 740il
    Thank you. So basically its just a matter of switching parts over to be compatible? the block and head are the same? Thank you again
    Philadelphia, PA
    2005 M3 & 2004 330i
    The 01 crank pulley has a 5-rib pulley for the AC belt while the 03s have a 4-rib pulley. I think you can just use the 4-rib belt on the 5-rib pulley without any real consequence though.
    03+ cars also got different ignition coils, so you'll have to grab the valve cover and coils from your original engine.
  1. Differences between the '01 740i Sport and '03 540i M-Sport?
    By Gator325525 in forum 1995 - 2001 (E38)
    Last Post: 08-27-2013, 03:32 AM
  2. Replies: 34
    Last Post: 03-14-2011, 12:11 PM
  3. How different are they?
    By catch22 in forum 1999 - 2006 (E46)
    Last Post: 11-08-2009, 11:04 AM
  4. Any differences between the 01 M5 and 02/03?
    By Imola in forum 1996 - 2003 (E39)
    Last Post: 12-08-2003, 08:10 AM
