Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 129
Thread: Jake's First Boost Endeavour (Keepin' It Together)
  1. #26
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by PEI330Ci View Post
    91 octane sadness.
    I'm going to have to be really careful with the knock traces...
    Excellent Calculator.
    Thank you. Its been really helpful as a learning/teaching tool.
    If your motor is set up with proper pistons and is managing heat well (proper intercooler, turbo within its efficiency, etc) you can definitely push the boost by a bit. You also have to look at cam size... I have faith in you. [if im you] Id start lower 9-10psi and work up a couple psi at a time. I assume you can log knock full time so that helps. Theres some unsolicited advice, but let me know if i can help with anything.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #27
    Mar 2013
    Upstate NY
    M3
    Bfc is sort of go big or go home you do not need a 700whp car to be fun. Infact my measily 500whp car is way to much power for correctly going around a corner... so I'm opting to turn down the boost to 10lbs when doing the twisties. I don't run racing slicks on the street and I don't know to many people that do. So don't feel like you need all this power. If your making it a straight line car then yes you'll always want "more." Build what you want not what bfc wants. Now as what's already been said you need lower compression for sure, especially if you only have 91Oct.
    Also if you ever think it's slow go beat up and down a mountain road like you would in a straight line if you survive and still think it's slow report back.
  3. #28
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    I have 93 octane locally. I meant to write e85 was not available near me. I know a few things about myself and one is that I will always want more power. That said I don't need to drive around at 500whp all the time. I really would like this engine to last awhile as well as my drivetrain.
    Can I use rajicase's old to tune to run my engine with lowered compression and a 257sxe?
  4. #29
    Mar 2013
    Upstate NY
    M3
    Yes you could easily but the s257sxe is a 500-520whp turbo. So if you intend to want more I'd run a s363 or Garret equivalent. I'm not to knowledgeable about compression and octane limits but general consensus is stock comp limit with pump gas is 400ish whp
    On another note I really enjoy my s257sxe was the perfect choice for me. Full boost at 3300 and does not have any boost taper.
  5. #30
    Nov 2014
    Bellingham, Wa
    I don't want or need more then 500whp and if I do want the more some day I will have a different engine. That's just what I wanted to hear full boost at 3300 rpm is awesome.
    I will be adding a spacer so that I can see what that turbo can do. I actually think it's a good thing that it maxes out a little over 500whp.
  6. #31
    Mar 2013
    Upstate NY
    M3
    I love it and as long as you get a correct oil drain you won't kill this turbo. Spool may vary as well I'm twinscroll with a s52. Oh they are cheap compared to most on the market.
  7. #32
    Nov 2014
    Bellingham, Wa
    The fact that you can buy a new turbo for under $800 is really great. I will be using a twin scroll manifold as well. What exhaust housing are you using?
  8. #33
    Mar 2013
    Upstate NY
    M3
    Ported 1.00, it has t4 flange but the actual ports on the exhaust inlet is t3 sized. You should really open the ports up and match them to your manifold. Easy work with a carbide bit.
  9. #34
    Nov 2014
    Bellingham, Wa
    I was considering the 1.00 and the .83 housings. I'm glad you chimed in and it's good to know that you ported your housing. I will enjoy doing the port work as well. Being topmount, I will also be able to switch housings easily if I feel the need to.
  10. #35
    Nov 2014
    Bellingham, Wa
    PARTS ORDERED! I have placed my order for the cutring and spacer combo from CES.
  11. #36
    Toronto, Canada
    E36 Turbo
    I'm a big fan of having lots of power on tap, but IMO the E36 chassis and drive line is very happy around the 500 whp mark, and will probably be a big handful for the majority of drivers especially if they're new to that kind of power level.
  12. #37
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by vollosso View Post
    I was messing around with that calculator. Is that true with m50 crank, pistons, cutring and spacer you can run 30+ psi on 93oct ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  13. #38
    Nov 2014
    Bellingham, Wa
    Quote Originally Posted by NOTORIOUS VR View Post
    I really don't want or need to have 500whp all the time. At 350-400whp I'll be happy and hopefully have a bit more reliability. I have driven few cars around 400hp but don't have a ton of experience. I really want to start slowly and not rush to get to the max power potential. I would rather spend money on things other then drivetrain components for the foreseeable future.
  14. #39
    Mar 2012
    Renton, Wa
    98 m3
    The calculator calculates the maximum ECR a fuel can withstand. It doesn't take into account anything further.
    So yes theoretically 8:1 compression, 93, and 30 psi works.
    I think heat would be a problem there. I may adjust the model to reduce that number... 8:1 is silly low compression..
    1989 535i - sold
  15. #40
    Nov 2014
    Bellingham, Wa
    Pulled the head this morning and dropped it at the machine shop. It may be done tomorrow morning if not this afternoon. The turbo kit arrived and my cutring combo gets here Monday.
    Time to focus on getting the shell together.
  16. #41
    Nov 2014
    Bellingham, Wa
    6 hour turn around from the machine shops pretty good.
  17. #42
    Mar 2013
    Upstate NY
    M3
    Gonna lap the valves or just run it as is? I'd recommend that and new valve seals. Budget oriented rebuild that works well.
  18. #43
    Nov 2014
    Bellingham, Wa
    That was already done when I assembled the motor 600 miles ago. Should be good to go.
  19. #44
    Nov 2014
    Bellingham, Wa
    When installing the cutring and spacer where should I put the rtv around the timing cover. Under the copper and on top as well as the gasket itself?
  20. #45
    Mar 2016
    Australia
    e30 318i, 135i
    Quote Originally Posted by jakeE36325 View Post
    apply it on the joints between the block and the timing cover i.e. under the copper spacer. That is all.
  21. #46
    Apr 2006
    Minnesota eh?
    86 325es
    I would put a tiny smear the whole way around the front of the timing cover under the spacer. When they leak it is a bitch to get them to stop.
  22. #47
    Nov 2014
    Bellingham, Wa
    Well sh!t. I did a final look over the head right before I was going put it on and found a really small crack between the coolant passage and the exhaust valve. Of course I already copper sprayed the spacer and put rtv ont the timing cover.
  23. #48
    Mar 2013
    Upstate NY
    M3
    Yep these heads like to crack if they see to much heat. Good thing they are a dime a dozen.
  24. #49
    Nov 2014
    Bellingham, Wa
    Yeah I'm just surprised I didn't notice anything when I ran it before. I have another head. Going to really make sure it's good this time.
  25. #50
    Mar 2013
    Upstate NY
    M3
    Last one I grabbed was only 20$ at the local pull a part. I should of grabbed another.
  1. Keepin' it on the snow where it belongzzz!!! (Pics)
    By Jed in forum Middle Atlantic - US
    Last Post: 12-21-2009, 02:43 PM
  2. First new 545 makes it into SoCal (Not 56k Friendly)
    By DasAutokerl in forum BMW Rides & Events
    Last Post: 11-05-2003, 09:34 PM
  3. keepin it short
    By kalib0y in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-28-2003, 11:58 AM
  4. AMD needs to get it together soon!
    By Tai Pham in forum Off-Topic
    Last Post: 10-19-2002, 03:19 PM
  5. 330i first day i got it
    By Infoe330i in forum 1999 - 2006 (E46)
    Last Post: 09-09-2001, 12:23 AM
