Results 1 to 2 of 2
Thread: subframe lowering to access differential bushings
    Jun 2013
    Tampa florida
    M-5, 99 Touring, 2k 525
    M-5 2000
    Son and I have the differential ready to come out to replace the differential bushings this morning.
    Need to get about 1-inch of clearance to replace the passenger rear differential bushings by dropping the subframe just a little.
    Wondering how far the subframe can be lowered before you have to start disconnecting things? If this is possible what needs to be removed to make this happen. On my 99 wagon I remember doing this vaguely when I did the subframe bushings.
    This is not about removing the subframe just lowing it enough to access the and replace differential bushings.
    Thanks in advance.
    Jun 2013
    Tampa florida
    Car is gong back together I am a little unclear of the torque values.
    Drive shaft to differential?
    Differential to subframe?
    1/2 Shafts?
    Subframe bolts?
  1. M-5 2000 Differential bushing and dropping subframe for access
    By Tampa 325ic in forum 1996 - 2003 (E39)
    Last Post: 04-26-2017, 08:45 AM
  2. .:Cut and raised my subframe 1" to lower car more
    By vtgti in forum 1975 - 1983 (E21)
    Last Post: 03-05-2012, 11:11 PM
  3. What rear subframe and differential bushings do you have?
    By catalyst. in forum 1991 - 1999 (E36)
    Last Post: 03-11-2009, 09:44 PM
  4. Best Place to buy Front lower control arms and bushings?
    By ecko457 in forum 1991 - 1999 (E36)
    Last Post: 08-11-2008, 11:53 AM
  5. Need tool to R/R bushing for lower control arm to trailing arm
    By fast4d in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-18-2006, 08:54 AM
