Results 1 to 2 of 2
Thread: M-5 2000 Differential bushing and dropping subframe for access
    Jun 2013
    Tampa florida
    M-5, 99 Touring, 2k 525
    M-5 2000
    Son and I have the differential ready to come out to replace the differential bushings this morning.
    Need to get about 1-inch of clearance to replace the passenger rear differential bushings by dropping the subframe just a little.
    Wondering how far the subframe can be lowered before you have to start disconnecting things? If this is possible what needs to be removed to make this happen. On my 99 wagon I remember doing this vaguely when I did the subframe bushings.
    This is not about removing the subframe just lowing it enough to access the and replace differential bushings.
    Thanks in advance.
    Jun 2013
    Tampa florida
  1. e36 323i coupe differential bushes and front bolt
    By alex86 in forum 1991 - 1999 (E36)
    Last Post: 07-20-2009, 08:32 PM
  2. What rear subframe and differential bushings do you have?
    By catalyst. in forum 1991 - 1999 (E36)
    Last Post: 03-11-2009, 09:44 PM
  3. new differential bushings and/or vac dsb?
    By Ian 328is in forum 1991 - 1999 (E36)
    Last Post: 02-24-2009, 11:55 PM
  4. Need front and rear subframes for 2002 E39 540i 6-speed
    By M3inSC in forum 1996 - 2003 (E39)
    Last Post: 08-11-2008, 01:14 AM
  5. Rear Subframe + RTAB Bushings and new differential installed.
    By vinnymac in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2007, 07:34 PM
