Results 1 to 7 of 7
Thread: E46 325 Misfire and following problems
    Dec 2016
    Brisbane
    e46 325ci
    Hi, i currently own a e46 2005 325ci and have only put 3000 km (171987 KM) on the clock from the previous owner. in this time i have replaced
    - Brake pads and Rotors $930
    - Expansion tank on twice, top hose, thermostat, rocket cover gasket cover and pipe - $1350
    - Check engine light = Cylinder 1 misfire, replaced spark plugs and 1 coil pack as well as both front struts and a front passenger head light $1138
    so as you can see i have spent quite the amount of money on the car since purchase, now having just sorting out the cyl 1 misfire not two days a go i already have another check engine light, i have not had this coded yet but i was wondering if anyone knows anything that could help? could be mechanic didn't fit something properly, or it could be something really simple or these are preemptive signs of something more serious? Cheers.
    sorry for re post wasn't getting much attention on the other sub
    Dec 2013
    Chicagoland area
    EXOTICS
    Honestly, if you are not able to DIY on most repairs, except the truly difficult,
    then a BMW would not be an affordable option for DD transportation.
    A BMW automobile that requires visits to a dealer or BMW specialist shop,
    for everything from simple diagnostics to minor maintenance and beyond,
    because the owner is disinterested or unskilled in DIY repairs,
    is not an affordable option for the average person, sorry.
    Dec 2013
    Chicagoland area
    EXOTICS
    Now if you are ready to jump into the deep end,
    dig into required research, along with asking for,
    and accepting helpful advice and tips from forum members,
    Welcome to BMW ownership and a continuing DIY learning curve.
    Dec 2016
    Brisbane
    e46 325ci
    to be fair i am only starting to learn DIY now, i have bought a scanner and i replaced the first expansion and second expansion tank myself as as yesterday replacing the headlight wiring. So i am up to DIY just lacked skill.
    Dec 2016
    Brisbane
    e46 325ci
    Dec 2013
    Chicagoland area
    EXOTICS
    Well then my second post applies, welcome to the forums!
    Fresno, CA
    2002 330i, 2000 528iT
    DIY would have probably saved you around $1,500 in that price list you have listed.
    I just replaced all 4 brake pads and rotors on my sisters 330ci for literally just under $295.45 shipped (VIP FCP memeber) and took about 3 1/2 hours including flushing the brake fluid.
    Regarding your code, you need to hook up the reader. Can't just guess a problem without the code and symptoms (if present).
    That's one of the big issues with owning an older vehicle. If you can't do things yourself, it makes it hard to justify owning.
    The money you will save on labor will buy one hell of a toolset...
    | 2002 330i 5-SPD - 101k | 2000 528iT - 146k |
    My E46 Maintenance Thread http://forum.e46fanatics.com/showthread.php?t=1124584
  1. E46 325 Misfire and following problems
    By riley111 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-24-2017, 12:22 AM
  2. A cool misfire and other problems
    By Larkin660 in forum 1988 - 1996 (E34)
    Last Post: 10-05-2011, 12:34 PM
  3. e46 330i misfires and lean banks 1 and 2
    By MoeMuny in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-12-2010, 02:48 PM
  4. e46 330i misfires and lean banks 1 and 2
    By MoeMuny in forum 1999 - 2006 (E46)
    Last Post: 03-02-2010, 11:19 AM
  5. 325 misfire and bad / rough idle
    By SHOracer in forum 1991 - 1999 (E36)
    Last Post: 03-23-2005, 04:35 AM
