Results 1 to 5 of 5
Thread: F02 needs oil change... what tools do I need outside filter, 17mm socket, 8.5 qts oil
    Apr 2017
    Maryland
    750 Li 328i
    Trying to change 2011 750 Li xdrive Oil since dealer said I'd have to do it myself since I only have 3700 more miles to reach 12k??? My oil needs changing. What other parts and tools do I need? Wanting to change it this weekend while I have time and a lift for $8 an hour. Thanks
    Texas
    '01 s54 M Coupe; '11 750
    Not trying to be an a-hole, but try the search for basic maintenance (and most other things).
    https://www.bimmerforums.com/forum/s...5#post29641065
    I would not wait 12k between changes. I go every 5k, and the oil is still as black as can be.
    You don't need a 17 mm wrench. You'll need an 8 mm allen socket, a 6 mm allen if your oil filter has a drain on it. You'll also need an 8 mm socket to remove the access cover if its still in place. And don't forget the most important part: a oil filter removal tool. These have to be a specific size, and I'm not sure if you'll find one at an auto parts store. You could possibly use one of the generic strap wrenches, but access is very limited and I don't think it would work.
    Oh, you need 10 quarts of oil. Not 8.5
    Apr 2017
    Maryland
    750 Li 328i
    Appreciate the help fellas...
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by Troy99 View Post
    Sounds like you may not be familiar with the online BMW TIS website...which is a great resource for DIY ownership. I highly recommend that you save/bookmark the link for future reference. It is an invaluable resource for looking up not only DIY information...but for just basic understanding of features and systems...as well as wiring diagrams and component locations.
    Click the following link then enter the last 7 digits of your VIN (or select appropriately for you chassis/model)...then type SERVICE ENGINE OIL into the search box. This should give you written instructions for changing the oil along with pictures and other links for further information: https://www.newtis.info/tisv2/a/en/
  1. What tools do i need...
    By Topless Bimmer in forum 1991 - 1999 (E36)
    Last Post: 06-23-2012, 05:06 PM
  2. Replies: 8
    Last Post: 10-01-2011, 09:24 PM
  3. What tools do I need for a Radiator change?
    By Realhotguy77 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-05-2009, 01:56 PM
  4. Oil change - What else do you do?
    By 96328is in forum 1991 - 1999 (E36)
    Last Post: 04-01-2005, 04:36 PM
  5. What tools do I need?
    By jsvizijr in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-21-2004, 02:03 PM
