Results 1 to 6 of 6
Thread: P1522 code problem
    Apr 2017
    South jersey.. New jersey
    2000 bmw 740il
    P1522 code problem
    I got a 2000 bmw 740 with vanos. Im a mechanic but I am so lost lol. I did the full timing on it as I have done lots of them..got all the right tools..well my bmw is throwing a p1522 code and both cam position sensors are working.. car runs like a dream. I don't understand what's going on..so any help would be very appreciative..thanks in advance
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Have you tried swapping the sensor to see if the code follows? Are they Bosch sensors?
    Apr 2017
    2000 bmw 740il
    With Both sensors plugged in I'm getting a code p1522.
    With driver side unplugged I'm getting p1340
    With pass side unplugged I'm getting po340
    So with both sensors plugged in I'm not getting the p1340 or po340 only P1522. But car runs like a dream
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    just a wild guess because your code(p1522) means the solenoid on bank2(left side) is getting mixed signals
    check:
    A) aftermarket cps sensor or B) melted wiring on the cps sensor
    2000 740i Sport
    Oct 2014
    Mesa AZ
    2000 740iL
    I was just battling a p1519 which is the same issue, but on the other bank. According to my research, these codes are nearly always timing issues. Your cams could very well be in time with the crank, but the computer does not think that they are. I would try retarding the cam trigger wheel a few degrees and see if the code goes away. I bought a cheap timing tool kit when I did my timing chain guides and feel like they may be the cause of my timing troubles.
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Quote Originally Posted by KinkedChrome View Post
    We did this to my friend`s m62tu engine but his code was p0011...Code did go away after retarding the bank 1 timing wheel a few degrees...
    ooops just realized your the same peep in the other post...Glad you finally got it timed
    2000 740i Sport
  1. Radio Theft Code Problem?!?!?
    By BumblBeeRacer in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-11-2004, 11:59 PM
  2. fault code problem
    By sprammer325is in forum 1991 - 1999 (E36)
    Last Post: 01-13-2004, 02:47 PM
  3. Radio Code problem...
    By vehemence in forum 1992 - 1999 M3 (E36)
    Last Post: 08-03-2003, 12:06 PM
  4. Factory Radio 'code' problems
    By Zoeb2s in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-21-2003, 02:12 PM
  5. Codes? Problem.
    By Cortech in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-10-2003, 10:53 PM
