Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: How often should OE radiator be replaced?
  1. #26
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    It just depends on the ambient environment is lives in, how much heat it sees all the time.
    ^^^^ that.
    Quote Originally Posted by gjVah View Post
    I've been through 5, they last anywhere from 500 to 10k miles. Funny thing is, the first 4 were Behr (the expensive OE option) my last one is Nissen (cheaper OE option) and is still in one piece (knock on wood).
    You are decidedly doing something wrong. I expect you are overfilling your expansion tank. A 540 run in Saudi Arabia should get more than 10k on a radiator.
    Quote Originally Posted by freethrowdunk View Post
    silicone tape*
    TOTALLY. That stuff is the mojo.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  2. #27
    Lawrenceville, GA
    4 BMWs.
    That's what I used to re-join the seat cables when I did the seat-twist fix.
    2001 Z3 3.0i -Oxford Green/Sandbeige
    2016 428xi -Estoril Blue II/Black
    2018 430iC- Estoril Blue II/Black
    2018 330it - Melbourne Red/Venetian Beige/Black
  3. #28
    Nov 2008
    M550iX, 540M-Sport, Scud
    My original factory radiator lasted around 4 years, 55k miles. Since then, I preventively replaced with oem Behr radiator at 123k miles, then 223k miles. I replace along with all the other cooling system parts....expansion tank, cap, all hoses, thermostat, water pump, fan clutch, etc.
    As you can surmise by the posts, its a bit of a crap shoot. Time, ambient temperature, miles and heat cycles all come into play.
    Replacement can depend on what level of reliability you need as well. If a failure is not going to put you out badly, then drive on. If it would be a huge inconvenience, then consider preventive replacement, but be sure to replace the expansion tank, cap, and that elbow piece mentioned above, as it is ordered separately and will start leaking if not replaced with the radiator.
    2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
  4. #29
    Mar 2008
    Hollywood, CA
    2003 525i
    Among the list of many items that take residence in the modified spare tire well: hammer, assorted tools, zip-ties, knee pads, unopened OE coolant, jump starter/air compressor....
  5. #30
    Feb 2009
    Hollywood, CA
    e39, e53, 957
    My overflow valves are not clogged. The only thing different between the ones that didn't last and this one that seems to be doing it's job for years is the brand.
  1. E#^ how often should fuel filter be replaced ?
    By enf1945 in forum 1991 - 1999 (E36)
    Last Post: 06-05-2012, 10:08 PM
  2. How often should brake pads be cleaned/greased?
    By robespierre in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-04-2008, 11:51 AM
  3. How often should rotors be replaced?
    By BMW Newbie in forum 1999 - 2006 (E46)
    Last Post: 10-04-2007, 03:49 PM
  4. How often should brake lines be replaced?
    By RobertFontaine in forum 1991 - 1999 (E36)
    Last Post: 09-20-2007, 11:56 PM
  5. How often should we replace the engine mounts?
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 11-10-2001, 01:27 PM
